Thanks for your replies everyone! Very cool to be talking to a 50 year electrical engineering expert.
It’s all working great with EmonLib, haven’t made the switch to CM yet because I don’t have a volt meter hooked up yet I’m just assuming 120 while I test things out.
I got two 100 amp clamps even though I’m only on 100 amp service because I am going to upgrade to 200 amp service soon, since with my car charger everything adds up to just over 100 amps, but the electrician who installed it assured me it was “technically within the 83% rule”.
I have one interesting physics question - I stupidly left my CT clamps disconnected, and open. I had actually opened them up to remove the burden resistors (I got the 100A:1v type). I did see another black component in there so I assumed that was the TVS diode and that would mean I was safe to leave them disconnected and open.
Well they were mostly fine, until I plugged in my car charger and it started drawing 30A@240. The entire panel started buzzing and I could physically feel the main supply wires that the clamps were on vibrating. I was trying to figure out what the heck was going wrong when I realized the vibration was changing depending on how I oriented the clamps. I quickly shorted them both with an alligator clip, and the buzzing and vibrating all instantly vanished.
I thought installing CT clamps was a fairly non-invasive harmless thing to do to your electrical system, but that vibration has taught me otherwise. Granted it was because of my stupid mistake and me not reading-the-freaking-manual, but still. I thought the TVS diode would protect me here, I guess it only protects the GPIO inputs of the Arduino.
I can say that the clamps are fine and undamaged despite the likely 10,000+ volts I was generating without any burden resistors. After calibrating them with a Kill a Watt, their Calibration Factor in Emonlib works out to about 57.7, which is not far off from the 60.6 default for a 5v Uno with a 33 ohm burden resistor.
But what the heck happened there? How was my mains wire vibrating just from having a clamp around it? It might have been the main breaker that was buzzing, which was in turn vibrating the mains wire, but why, what’s the physics at work here?
Eventually I’m going to have to disconnect those clamps again to take this project off the breadboard and into a proper box - what’s the proper procedure here, just get an alligator clip on them to short them as quickly as possible after pulling them out of the breadboard?
