What to buy and how will it help? octopus system
Be gentle, i know nothing about monitoring and why I would need one and how it works and the benefits… please don’t bambuzle me with science and math but if you want to explain in layman terms I’m listening and ready to learn.
so my system..
  • Octopus installed.
  • ASHP is Daikin EDLA04E2V3 sw=20017704 eeprom=1709232-18C
  • MMI Dakin with Bluetooth BRP069A78
  • room thermostat Madoka BRC1H52W
  • App is Onecta fw=7.7.0
i use home assistant to control the system ( instead of the madoka) in which i have a table of ambient temps with corresponding LWT target temps, so a WD compensation but i can change each value to make it non linear (whereas the MMI curve is linear) and i use Bluetooth room temperature sensors to further control the system. the mmi is set such that LWT temperature is the control mode. it seems to work fine and i don’t want to charge this.
But i would like to view more insight on performance of the system and check its cycling performance. COP etc
which one of your systems should i buy, what will it give me, is it easy to install with no soldering or rewiring etc.
