What is the feed template for a device with a virtual feed
Hi @TrystanLea and @johncantor I suspect you’ll both have well-informed opinions on this.
I have an Ecodan and for four months I’ve been tinkering and I have it running well. I’m trying to share what I’ve done and OpenEnergyMonitor seems like a good way to begin. I like how you have both been sharing your experiences.
Somewhat surprisingly, I’m actually controlling it entirely with MELCloud and not using any local control hardware. I did get an MMSP package installed so that means the installer fitted a flow meter and heat meters. As you know the UK government is funding these at the moment.
Anyway…I have a device file which Emoncms’ “device” module can import. It is setting up the inputs and feeds. No surprises there. I’m POSTing all my stats since October that I snaffled from MELCloud.
So, we’re all good. Except that I keep changing my mind about how to structure things. I thought it would help to import the raw inputs and then create virtual ones for things such as “heatpump_elec”.
I started creating a virtual feed template like this:
    "name": "heatpump_elec",
    "type": "DataType::REALTIME",
    "engine": "Engine::VIRTUALFEED",
    "processList": [
            "process": "source_feed_data_time",
            "arguments": {
                "type": "ProcessArg::FEEDID",
                "value": "HeatingEnergyConsumedRate1"
    "unit": "W"
but when I load it up the summary is “undefined” in a red pill (assumedly because prepare_feed_processes doesn’t like it). As you can tell, I’m trying to target the auto-populating fields in the “My Heat Pump” app which is working nicely.
I’ll admit I made up the “process” value after hacking around. I know JavaScript and PHP so deduced that this is likely to be plausible.
Of course it all works fine if I manually configure the virtual feed, but where’s the fun in that? I’m hoping to use Trystan’s device module to make this easier for others in the future.
I found some old examples, but I suspect they might be outdated.
I’ve been digging around for a number of hours and thought it was about time to call in some well-informed heads to guide me.
Perhaps Trystan will just tell me to use postprocess and stop trying to be clever with virtual feeds.
David Bowen
Hello @MyForest
Great to hear your experience and efforts with the EcoDan and monitoring.
I’m not that knowledgeable on virtual feeds unfortunately, I do do all my configuration with either input processing or sometimes post processing.
The best person to ask about Virtual feeds is @nchaveiro but the issue with the device module template may well result from more recent development that I helped with.
I tried the following full template and could replicate what you describe so it looks like this is a bug. I have created an issue here to keep track of this one Creation of device templates with virtual feeds does not work · Issue #51 · emoncms/device · GitHub
    "name": "VirtualFeedTest",
    "category": "VirtualFeedTest",
    "group": "VirtualFeedTest",
    "description": "VirtualFeedTest",
    "inputs": [
            "name": "raw_input_1",
            "description": "raw_input_1",
            "processList": [
                    "process": "log_to_feed",
                    "arguments": { "type": "ProcessArg::FEEDID", "value": "raw_feed_1" }
    "feeds": [
            "name": "raw_feed_1",
            "engine": "Engine::PHPFINA",
            "interval": "10",
            "unit": "W"
            "name": "virtual_feed_1",
            "processList": [
                    "arguments": {
            "unit": "W"
Awesome, thanks Trystan, that’s a very fast response.
This isn’t blocking me - I can re-design my stuff and keep re-playing the old data through until I get the design right. So please don’t panic too much about fixing it if you’ve got other things to sort out at the moment.
Keep up the good work.
