What is default baud rate for monitoring emonESP via serial port?
What is default baud rate for monitoring emonESP V3.1.4 via serial port?
I’m not sure I understand.
The emonTx communicates with the ESP8266 at 115200 baud - unless you are running the 3-phase sketch, which can only support speeds up to 9600 baud.
