I use the newest version 11.2.3 on a shared webhoster with php 8.1. The emoncms runs well, all data are recording.
On an other webpage with PHP 7.4 i have embbeded the follow
Leistung Wechselrichter 1 / W
But now i got an Warning:
Deprecated: preg_replace(): Passing null to parameter #3 ($subject) of type array|string is deprecated in /home/xxxx/web/emon.xxxx.xx/public_html/Modules/vis/vis_controller.php on line 106
