boelle
(Bo Herrmannsen)
#1
flashing the oct 2017 image to a new sd card
while the image is downloading i’m wondering what folders/mount points are on the write enable partition?
i’m going to add a speedtest script and that saves to a spreadsheet hence the need that it outputs to a place that is write enabled all the time
boelle
(Bo Herrmannsen)
#2
might be able to answer this one myself as i did not do a good enough search
/dev/mmcblk0p3 /home/pi/data ext2 defaults,rw,noatime,nodiratime,errors=remount-ro 0 2
so i should just save in a new folder under /home/pi/data
is that correct?
Greebo
(Greebo)
#3
Yes, that is the standard “always read-write” mount point.
boelle
(Bo Herrmannsen)
#4
that worked fine
but while i’m at it i might as well update i thought
sudo apt-get update
sudo apt-get upgrade
but i get connection errors
Err http://mirrordirector.raspbian.org jessie/rpi armhf Packages
Unable to connect to mirrordirector.raspbian.org:http:
Err http://mirrordirector.raspbian.org jessie/contrib Translation-en_GB
Err http://mirrordirector.raspbian.org jessie/main Translation-en_GB
Err http://mirrordirector.raspbian.org jessie/non-free Translation-en_GB
Err http://mirrordirector.raspbian.org jessie/rpi Translation-en_GB
i wonder if others has the same issue?
boelle
(Bo Herrmannsen)
#5
