Hi all,
I have a power feed that contains negative values when electricity is being injected to the grid (PC system), and positive values when it’s being drawn.
I would like to compute injected kWh per hour from that feed. I can do that from the input (reset to zero if > 0, * -1, Power to kWh), why can’t I do the same when setting up a virtual feed?
Is there a fundamental reason why the same processing steps we have for inputs are not available for virtual feeds?
Thanks!
Franck
