I’m trying to use a virtual feed, and i’m getting strange results.
I create a virtual feed using the KWhd feed and when i compare the virtual feed with the feed KWhd the results are not the same.
I´m doing something wrong?
Thanks in advance.
Attached some pictures:
How is your virtualfeed configured?
Was this ever resolved? I’ve got the same issue. Essentially: Real Feed = :Solar kWh Virtual Feed = : Real Feed then Multiply by -1. When I plot a graph of both, they are different.
[See Graphing with Virtual Feeds not stacking up - Moderator (RW)]
