I have a virtual feed that calculates my inverters charging current, what would be the best approach to get a virtual feed to show kwh of the inverters charging current
As far as I know, this is not possible with virtual feeds.
You’ll need to process the inputs, and use the Power to kWh process to write kWh to a feed. Note: you may experience some glitches when subtracting feeds, as they may be slightly out-of-sync with the input.
Just a small point - the symbol for Watts is capital W (as it is the name of a person). I edited the subject and yes, it is a hill I’d die on :rofl:
Thanks @Timbones, I did this lets see how it goes
