Command line Python script to GET/SET VE.Direct Hex Protocol for Victron devices.
VE.Direct Hex Protocol MPPT
VE.Direct Hex Protocol BMV
VE.Direct Hex Protocol Phoenix Inverter
# Created on Mar 13, 2022
# @author: lsimmons
import sys, getopt, serial
ver = "v1.2 03/24/2022"
def main ( argv ):
port = ''
cmd = ""
try:
opts, args = getopt.getopt ( argv,"hp:c:", ["port=","cmd="] )
except getopt.GetoptError:
print ( "vedirecthex.py -p <port> -c <cmd>" )
sys.exit(2)
for opt, arg in opts:
if opt == '-h':
print ( 'vedirecthex.py -p <port> -c <cmd>' )
sys.exit()
elif opt in ("-p", "--port"):
port = arg
elif opt in ("-c", "--cmd"):
cmd = arg
print ( "===========")
print ( "vedirecthex")
print ( ver )
print ( "port: " + port )
ser = serial.Serial ( port, 19200, timeout=10 )
ser.close()
ser.open()
ser.write ( str.encode ( ":451\n" )) # get product ID
read_val = ser.read ( size = 16 )
print ( "prod: " +bytes.decode ( read_val ))
ser.close()
ser.open()
print ( " cmd: " + cmd )
ser.write ( str.encode ( cmd + "\n" ))
read_val = ser.read ( size = 256 )
print ( " res: " + bytes.decode ( read_val ))
ser.close()
if __name__ == '__main__':
pass
main ( sys.argv[1:] )
Use examples:
python3 /opt/vedirect/vedirecthex.py -p /dev/ttyUSB1 -c :7A8ED00B9 # GET Example
python3 /opt/vedirect/vedirecthex.py -p /dev/ttyUSB1 -c :89DED00F609C4 # SET Example
Command examples:
# Load Control
:7A8ED00B9 # get load output state
:7ABED00B6 # get load ctrl state
:8ABED0000B5 # set load ctrl state off
:8ABED0004B1 # set load ctrl state on
:8ABED0005B0 # set load ctrl state user1
:79CED00C5 # get switch low level
:79DED00C4 # get switch high level
:89CED002E098D # set switch low level to 23.50 volts
:89CED00FC08C0 # set switch low level to 23.00 volts
:89CED00CA08F2 # set switch low level to 22.50 volts
:89CED00980824 # set switch low level to 22.00 volts
:89DED00280A91 # set switch high level to 26.00 volts
:89DED00F609C4 # set switch high level to 25.50 volts
:89DED00C409F6 # set switch high level to 25.00 volts
:89CED00B2040E # set switch low level to 12.02 volts
:89DED001605A8 # set switch high level to 13.02 volts
# Street Light Function
:7EDCC0095 # get streetlight function
# Miscellaneous
:352 # application version
:451 # product ID
:64F # restart
:7F0ED0071 # get battery max current
:8F0ED0064000C # set battery max current to 10.0A
Calculating the checksum for commands:
Message example from MPPT documentation
Set battery maximum current
set to 10.0A = 0x0064
: start
8 set command
F0 register (EDF0)
ED
00 flags
64 data (0064)
00
0C checksum
0x55-0x08-0xF0-0xED-0x00-0x64-0x00 = 0x0C
