I was just using certbot on my emonHub and python was reporting failures to write to /var/log. So I checked and /var/log is 100% full.
pi@emonpi(rw):log$ df -h
Filesystem Size Used Avail Use% Mounted on
/dev/root 3.4G 2.0G 1.3G 62% /
devtmpfs 483M 0 483M 0% /dev
tmpfs 487M 0 487M 0% /dev/shm
tmpfs 487M 56M 432M 12% /run
tmpfs 5.0M 4.0K 5.0M 1% /run/lock
tmpfs 487M 0 487M 0% /sys/fs/cgroup
tmpfs 40M 6.6M 34M 17% /var/lib/openhab
tmpfs 1.0M 0 1.0M 0% /var/lib/dhcp
tmpfs 1.0M 8.0K 1016K 1% /var/lib/dhcpcd5
tmpfs 50M 50M 0 100% /var/log
tmpfs 30M 48K 30M 1% /tmp
/dev/mmcblk0p1 60M 21M 40M 35% /boot
/dev/mmcblk0p3 25G 1.8G 22G 8% /home/pi/data
The files taking up the most space are the emoncms.log files.
pi@emonpi(rw):log$ ls -l
total 49420
drwxr-xr-x 2 root adm 80 Jul 2 23:17 apache2
-rw-r----- 1 root adm 626688 Jul 9 18:36 auth.log
-rw-r----- 1 root adm 1056218 Jul 3 09:17 auth.log.1
-rw-r----- 1 root adm 1053608 Jun 30 11:17 auth.log.2
-rw-r--r-- 1 root root 7029 May 24 18:04 boot.log
-rw------- 1 root utmp 4992 Jul 5 11:40 btmp
-rw-r----- 1 root adm 626688 Jul 9 18:35 daemon.log
-rw-r----- 1 root adm 1054505 Jul 1 23:17 daemon.log.1
-rw-r----- 1 root adm 1053409 Jun 27 02:17 daemon.log.2
-rw-r----- 1 root adm 1014 May 24 18:03 debug
-rw-rw-rw- 1 root root 16105472 Jul 9 18:36 emoncms.log
-rw-rw-rw- 1 root root 2097152 Jul 9 18:17 emoncms.log.1
-rw-rw-rw- 1 root root 1032192 Jul 9 17:17 emoncms.log.2
-rw-rw-rw- 1 root root 13164544 Jul 9 16:17 emoncms.log.3
drwxr-xr-x 2 emonhub root 60 May 24 18:03 emonhub
drwxr-xr-x 2 pi root 60 May 24 18:03 emonpilcd
-rw-r----- 1 root adm 606208 Jul 9 18:20 kern.log
-rw-r----- 1 root adm 1074933 Jul 4 00:17 kern.log.1
-rw-r----- 1 root adm 1076545 Jul 3 06:17 kern.log.2
drwx------ 2 root root 480 Jul 9 18:21 letsencrypt
drwxr-xr-x 2 pi pi 80 Jul 9 18:17 logrotate
-rw-r----- 1 root adm 606208 Jul 9 18:20 messages
-rw-r----- 1 root adm 1074933 Jul 4 00:17 messages.1
-rw-r----- 1 root adm 1076545 Jul 3 06:17 messages.2
drwxr-xr-x 2 mosquitto mosquitto 60 May 24 18:03 mosquitto
-rw-rw-rw- 1 root root 0 May 24 18:03 mqtt_input.log
drwxr-xr-x 2 mysql adm 60 May 24 18:03 mysql
-rw-rw-rw- 1 root root 0 May 24 18:03 mysql.log
-rw-rw-rw- 1 root root 0 May 24 18:03 ntp_update.log
drwxr-xr-x 2 openhab openhab 100 Jun 21 03:11 openhab
drwxr-xr-x 2 redis redis 60 May 24 18:03 redis
-rw-rw-rw- 1 root root 491520 Jul 9 18:36 service-runner.log
-rw-rw-rw- 1 root root 1048684 Jun 21 18:17 service-runner.log.1
drwxr-xr-x 2 root root 60 May 24 18:03 supervisor
-rw-r----- 1 root adm 892928 Jul 9 18:36 syslog
-rw-r----- 1 root adm 1091782 Jul 4 00:17 syslog.1
-rw-r----- 1 root adm 1126311 Jul 3 10:17 syslog.2
-rw-r----- 1 root adm 376832 Jul 9 18:20 ufw.log
-rw-r----- 1 root adm 1066596 Jul 4 04:17 ufw.log.1
-rw-r----- 1 root adm 1052964 Jul 3 10:17 ufw.log.2
-rw-rw-r-- 1 root utmp 24576 Jul 9 18:30 wtmp
So I looked at emoncms.log and it has lots and lots of this:
2018-07-04 20:17:04.637|ERROR|input_controller.php|Reached the maximal allowed number of diferent NodeIds, limit is 32. Node '17' was ignored.
2018-07-04 20:17:04.761|ERROR|input_controller.php|Reached the maximal allowed number of diferent NodeIds, limit is 32. Node '17' was ignored.
2018-07-04 20:17:04.943|ERROR|input_controller.php|Reached the maximal allowed number of diferent NodeIds, limit is 32. Node '17' was ignored.
2018-07-04 20:17:05.205|ERROR|input_controller.php|Reached the maximal allowed number of diferent NodeIds, limit is 32. Node '17' was ignored.
2018-07-04 20:17:05.274|ERROR|input_controller.php|Reached the maximal allowed number of diferent NodeIds, limit is 32. Node '17' was ignored.
2018-07-04 20:17:05.570|ERROR|input_controller.php|Reached the maximal allowed number of diferent NodeIds, limit is 32. Node '17' was ignored.
2018-07-04 20:17:05.643|ERROR|input_controller.php|Reached the maximal allowed number of diferent NodeIds, limit is 32. Node '17' was ignored.
2018-07-04 20:17:05.883|WARN|PHPFiwa.php|PHPFiwa:post failed to fetch meta id=88088
2018-07-04 20:17:05.893|WARN|PHPFiwa.php|PHPFiwa:post failed to fetch meta id=88089
2018-07-04 20:17:05.903|WARN|PHPFiwa.php|PHPFiwa:post failed to fetch meta id=88122
2018-07-04 20:17:05.921|WARN|PHPFina.php|post() padding max block size exeeded id=88117, 12904994 dp
2018-07-04 20:17:05.942|ERROR|input_controller.php|Reached the maximal allowed number of diferent NodeIds, limit is 32. Node '17' was ignored.
2018-07-04 20:17:06.101|WARN|PHPFiwa.php|PHPFiwa:post failed to fetch meta id=88088
2018-07-04 20:17:06.111|WARN|PHPFiwa.php|PHPFiwa:post failed to fetch meta id=88089
2018-07-04 20:17:06.125|WARN|PHPFiwa.php|PHPFiwa:post failed to fetch meta id=88122
2018-07-04 20:17:06.145|WARN|PHPFina.php|post() padding max block size exeeded id=88117, 12904994 dp
2018-07-04 20:17:06.168|ERROR|input_controller.php|Reached the maximal allowed number of diferent NodeIds, limit is 32. Node '17' was ignored.
2018-07-04 20:17:06.295|WARN|PHPFiwa.php|PHPFiwa:post failed to fetch meta id=88088
2018-07-04 20:17:06.304|WARN|PHPFiwa.php|PHPFiwa:post failed to fetch meta id=88089
2018-07-04 20:17:06.323|WARN|PHPFiwa.php|PHPFiwa:post failed to fetch meta id=88122
First of all, what should I do to clear the logs? Just rm them and allow new logs to start posting?
Second, any idea what is going on?
