Vaillant sensoCOMFORT - zone is missing sensor information (actual flow temp.)
Hello there! I recently got my heat pump installed (Vaillant AroTherm Plus 12kw). After trying to heat up the house via two configured UFH zones, I noticed that one of the zones is not picking up sensor data (looks like it’s not ‘assigned’?), even though I can see the correct sensor data reported via the “Sensor/actuator test”. Because of this, I assume it’s the reason why only one of my zones is heating properly (sensor works to heat pump can ramp up and down), while the other zone stays on a fixed value (that is quite low).
I hope there’s an easy fix to get it assigned! My installer is somewhat unhelpful and patronizing (“I’ve been doing this for 35 years”, “call Vaillant!”), so I’m asking here.
My basic system diagram code: 11
FM3 configuration: 1
FM3 MO: Not working
VR10 sensors connected to S5, S6 connectors of the VR70 box.
Thank you! :folded_hands:
