I’m assuming you mean the Vaillant reported COP in the MyVaillant App rather then an OEM calculated COP. If so have a look at this thread:
and follow the instructions in this part for checking if your Vaillant flow and return sensors are mis-reporting
As the thread describes it’s a really common problem with Vaillant Aerotherm systems. That said in theory you should also see that on you hot water too. MyVaillant App is misreporting my COP by over 33% due to temp sensor issues
