(V10.0.2) Dashboard selection in side bar not working when logged out
When logged in dashboard selection works fine. When logged out I get a fault:
406 Not Acceptable
URI not acceptable. UserNameid18 cannot respond to “” .
(where UserName is the user name…)
Dash board is set to public.
The new link looks like this: myhost.com/emoncms/UserName%252526id%25253D18
If I manually type the url using the old scheme ie. myhost.com/emoncms/UserName&id=18
it still works fine.
This is possibly and edge case as I can’t see any other topics on it.
Rob
Where do you find that new link?
I prefer just using the read API key rather than making dashboard fully public, more secure this way e.g
emoncms/dashboard/view&id=XX&apikey=XXXXX
I just copied it out of the address bar, same result when I right click on the dashboard link in the side panel.
I agree completely about the security, but I find it useful for general public viewing. A work around which I just tried is to have a hard link on the dashboard itself.
Ahh, I’ve found the problem.
I found that some links to dashboards were working and some weren’t. The links that did work used: myhost.com/emoncms/UserName/DashboardAliasName
The links that didn’t work had that other string of mumbo jumbo shown above.
I logged into the account and sure enough some of the dashboards didn’t have alias names. Once giving them names it worked.
Summary: Old version seemed to use Dashboard ID numbers for link. New version uses Alias names for link. So you must have an alias name now.
Rob
