Through the help of this forum I posted and got help figuring out how to send data to emoncms.org using only an ESP32/ESP8266.
Thank you for that help because I love emoncms.org and am converting everything over from Blynk.io.
For one of my sensors I need an adc and the ESP adc is very noisy and unusable. So for my present system I have an atmega328 where I use its adc and then send data using a software serial port to an ESP-01 and I get good clean data.
My problem is that I have some kind brain lock and I cannot figure out how convert my code to send data to emoncms.org with this same hardware.
And I canāt seem to find an answer after many hours of googling.There seems to be too many variables for me to hold in my head at the same time. For example, using a software serial port, and using the ESP-01 in its AT command mode.
Can anyone point me to code examples that I can work from?
Hi Steve, I donāt know if my comments will help you but⦠I donāt use the AT commands. I have an Arduino Mini Pro getting the voltage and current data, because of the better ADC. That data is sent to an ESP8266 by hardware serial, although software serial could also be used. The ESP8266 uses serial receive code ādistilledā aka vastly simplified from the emonESP code. The received data is then sent via http POST to emoncms.org. I can also send the data via MQTT to Node-REd, Home Assistant etc. I donāt claim any credit for the code as it is based on what I gleaned from the OpenEnergyMonitor documents. I am happy to share the code by email or Messenger if you wish.
Thank you bobcroft and Robert. With both your comments I am realizing that it does not talk using the AT commands built into the ESP-01. Probably why I got few results while googling.
Thank you for your offer bobcroft, it would be great if you could send it to [email protected].
And I will spend some time looking at this GitHub so thank you for that Robert.
Maybe a PM here (the Envelope icon when you click on your own icon in the blue header, right-hand side)? I think you both should have PMās available to you.
I have deleted my reply to Steve as I did not intend to put the files in a public domain although I am happy to share them with individuals.
It is not clear to me how to reply to people using the PM you refer to on a one to one basis. I think the best way is to exchange emails outside of the OEM forum. I had no idea that a simple offer of help could turn out to be such an issue.
Whereās the issue? For some reason, your email didnāt work - I suggested you use the PM facility. That means you donāt need to make your or anybodyās email address public. A PM is visible to the 3 Admins (Glyn, Trystan & Gwil) but to no-one else.
To access the PM, I think you need to be on the website, not contributing by email. Click on your Icon, then click the envelope twice. Youāll come to the Inbox page, with a list of other mailboxes below, and a (presumably empty) list of messages to the right. Click New Message below the list of mailboxes to generate a message. Youāll need the recipientās UserName, and thatās about all. A small disc appears attached to your Icon (on every page) when you have an incoming PM.
Hi Robert, that clarifies things. I think I was mixing up the wesite and contributing by email. Iāll see if Steve replies that he has received the files today.
Sorry, I should add:
-I am using a programming board which I know works with the ESP-01.
-I have tried a lower baud rate as low as -b 9600 and the window flashes so quick I cannot see it.
You may be interested to know we (well @FredM67) are developing an ESPHome component (for an ESP32 really) for communicating with an emonTX (primarily the new TX6 under developemnt).
