Hello all!
I would like to use the YHDC (SCT013-015) current sensor with the emonTX actual design. My home consumption is quite small (3,3kW máximum the hole house) and this is why I want to use this sensor, I will have more resolution, no?
. I note that this sensor has a voltage output instead a current one like the SCT013-000 (100A). ¿I have to make a hardware modification in order to use those sensors?
Thank you! I like very much this project and Forum!!
David.
