Using a Larger CT with a PZEM-004T
The split-core version of the CT that can be purchased with a -004T (PZCT-02) is rated at 100A:100mA.
I don’t know if the solid-core version of the CT has the same rating. I have a PZEM-004, which is a PZEM-004T with an LED display. The solid-core CT that came with it is rated at 100 Amps max, but I have no data on its secondary rating. My guess is that it’s the same, (or close) as the instrument can be purchased with either CT.
https://www.ebay.com/itm/384864196498?hash=item599bb19792:g:3q4AAOSwWYpibXuc
