I am trying to re-program my emonTx to read an analog input so I tried to upload the sketch using the Arduino IDE, but I have a comunication error. (avrdude: stk500_recv(): programmer is not responding)
I am using this cable, but not sure if it is possible because it doesn´t have a RST connection.
Anyone know if is it possible to program my EmonTx with a common USB to TTL cable??
From the Seeed Studio page at the link shown above:
Hello.
Could we use this to flash Arduino program ?
Regards, Dimitri Dujardin on Oct 19,2016
Hello, because it does not have the DTR/RTS wire for initiating the bootloader reboot sequence, it can not be used to flash Ardiuno program. Deray Wu on Oct 20,2016 10:47 AM
Actually it is possible to upload a sketch using a USB to serial adapter that doesn’t have a reset line if you manually operate the reset button yourself, it’s not ideal, but it is doable if you’re in a pickle or you just like doing things the hard way. eg upload sketch to standalone ATMega328P via serial port? - Raspberry Pi Forums
