Hi Stuart,
I am trying to load code into the cell module but somehow failed. I’m trying to upload code with protocol “usbtiny” using a USBISP device. I am constantly getting the following issue.
Using Port : usb
Using Programmer : usbtiny
Setting bit clk period : 16.0
avrdude: usbdev_open(): Found USBtinyISP, bus:device: bus-0:\.\libusb0-0001–0x1781-0x0c9f
AVR Part : ATtiny841
Chip Erase delay : 4500 us
PAGEL : P00
BS2 : P00
RESET disposition : possible i/o
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 6 4 0 no 512 4 0 4000 4500 0xff 0xff
flash 65 6 32 0 yes 8192 16 512 4500 4500 0xff 0xff
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
Programmer Type : USBtiny
Description : USBtiny simple USB programmer, http://www.ladyada.net/make/usbtinyisp/
avrdude: programmer operation not supported
avrdude: Setting SCK period to 16 usec
CMD: [ac 53 00 00] [00 00 00 00]
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.
avrdude done. Thank you.
*** [upload] Error 1
================================================================================================== [FAILED] Took 1.41 seconds ==================================================================================================
Environment Status Duration
attiny841_V421 FAILED 00:00:01.411
