I can make a clean restore, I¡ll try to make a step by step restore, any information how to restore manually and make manual y backup from old version to new version
hi,
It could be that this feed has null values and negative values, and this can generate this issue?
I have created a new SDwith latest image and then updates to latest emoncms and now using 10.2.3, after this I ahve resotred a backup from old version and all seems to work, but two feeds are not working, and are appearing as old data but I can’t see errors in logs:
old version working:
new version failing inputs:
consum is from a input:
seems taht since upgrade to altest emoncms no values from consum:
2020-06-07 12:03:02,600 DEBUG MQTT Publishing: emon/fronius/Inverter_status 4
2020-06-07 12:03:02,602 DEBUG MQTT Publishing: emon/fronius/AC_power_watts 438
2020-06-07 12:03:02,603 DEBUG MQTT Publishing: emon/fronius/AC_LifetimekWh 7076979.2
2020-06-07 12:03:02,604 DEBUG MQTT Publishing: emon/fronius/DayWh 1586
2020-06-07 12:03:02,606 DEBUG MQTT Publishing: emon/fronius/YearWh 2196172
2020-06-07 12:03:02,607 DEBUG MQTT Publishing: emon/fronius/TotalWh 7076979
2020-06-07 12:03:02,608 DEBUG MQTT Publishing: emon/fronius/sm_Power_watts -93.25
2020-06-07 12:03:02,610 DEBUG MQTT Publishing: emon/fronius/sm_TotWhExp 651688
2020-06-07 12:03:02,611 DEBUG MQTT Publishing: emon/fronius/sm_TotWhImp 6597098
2020-06-07 12:03:02,612 DEBUG MQTT Publishing: emon/fronius/sm_PhV 234.10000000000002
2020-06-07 12:03:02,614 DEBUG MQTT Publishing: emon/fronius/sm_WphA -72.07000122070313
2020-06-07 12:03:02,615 DEBUG MQTT Publishing: emon/fronius/consum nan
2020-06-07 12:03:02,616 INFO MQTT Publishing: emonhub/rx/12/values 4,438,7076979.2,1586,2196172,7076979,-93.25,651688,6597098,234.10000000000002,-72.07000122070313,nan
but on old version was working
How can I debug this issue?
Looks like fronius/consum is coming through as a nan value here?
Are you using the Fronius modbus interfacer in emonhub? it looks like its still archived here so there may well be issues with it?
This is the emonhub log I think?
Emoncms is recording what it is sent. Seems to be an emonhub issue.
Correct is emonhub.log, and this is an output generated with calculated formula on input, this in put works, but when I add calculated resilt with other values then fqils…
I cam generate feed calculated becuase virtual feed calculated is not supported to be added on mysolar app
Any suggestion how to solve both error or one of them?
Albert
El dl., 8 de juny 2020, 16:48, Brian Orpin via Community <noreply@community.openenergymonitor.org> va escriure:
You are going to have to post everything related to this because I do not understand how emonhub is involved in calculated values. I was expecting that it takes the data from the interface and publishes it to emoncms.
Currently, emonhub is publishing a NAN to emoncms - I think that is your problem.
Start with the emonhub log from restarting the service.
