Hello @gck303, the upload button doesnt work on the older versions Im afraid. I’ve not had much luck with the network mode, not that I’ve spent much time trying it. I usually use a USB to UART programmer and upload the firmware using the platformio instructions in the readme GitHub - openenergymonitor/EmonESP: ESP8266 WIFI serial to emoncms link
I will give it a go. I do not currently have a UART programmer setup, so it looks like an evening’s fiddling to get everything working. Plus, I have to unscrew it from the wall.
I have got my Ubuntu 20 laptop up and running. I normally use Win10, and installing anything looked rather involved.
I have got python 2.7.18 installed. PIP is installed and all the requirements are downloaded.
I have created a /home/pi directory and get the emonUpload tool from git. This no opens and gives me no errors. It downloads the latest updates when starting up.
Now, I am stumped on the UART programmer and connecting it to the emontx3 device. My UART programmer looks identical to the one mentioned in this video.
Do I need to add the button and jumper lead at 3:17?
Hello @gck303 aha it will be a bit more fiddly with that programmer as it’s designed for a different pin/connector configuration. If you can find the pinout digram you should be able to jumper across, though you will need male to female jumper wires to do that.
Alternatively it’s a bit easier with a programmer with a standard uart connector e.g ours here:
