Update issue from v9.8.24 to v10.1.10 on a shared server
Just tried to update from v9.8.24 to v10.1.10 on a shared server using @borpin 's suggested solution and run into the same topic: “Database error, you may need to run database update”.
then modified content of emoncmsdbupdate.php
chdir("/var/www/emoncms"); to chdir("/");
and copied it to my /www/htdocs/XXX/DOMAINNAME/emoncms directory and made it 777. After that I tried to run https://DOMAINNAME/emoncmsdbupdate.php which ended up in :
Warning : scandir(Modules): failed to open dir: No such file or directory in /www/htdocs/XXX/DOMAINNAME/emoncms/core.php on line 156
Warning : scandir(): (errno 2): No such file or directory in /www/htdocs/XXX/DOMAINNAME/emoncms/core.php on line 156
Did I completely wrong?
You need to run it from SSH I think as in
[edit]
Or - the path might need to be the real path on the shared server as / is the real root folder of the host.
As for the shared host I only have access to files via FTP and to MySQL via phpMyAdmin. So I cannot run SSH shells.
I modified emoncmsdbupdate.php with the full real path and it finally worked:
modified: chdir("/www/htdocs/XXX/DOMAINNAME/emoncms");
So thanks a lot @borpin !
