NA7KR
(Kevin Roberts)
5 October 2020 22:25
#1
How is best way to fix this:
Starting update via service-runner-update.sh (v3.0) >
emonSD version: emonSD-17Oct19
supported images: emonSD-24Jul20 emonSD-02Oct19 emonSD-17Oct19
emonSD base image check passed…continue update
git pull /opt/openenergymonitor/EmonScripts
master
stable
error: object file .git/objects/63/b614b2ce644039e2bd3a983787cceeed502768 is empty
fatal: loose object 63b614b2ce644039e2bd3a983787cceeed502768 (stored in .git/objects/63/b614b2ce644039e2bd3a983787cceeed502768) is corrupt
borpin
(Brian Orpin)
6 October 2020 17:07
#2
First take a backup!
Rerun the update, might just have been a git/network glitch.
Get a new SD Card and start with a new image.
NA7KR
(Kevin Roberts)
6 October 2020 23:39
#3
How do move all my seeings and data to a new SD card, sounds drastic,
Never updated from day 1 when received card.
There must be a way to fix it without doing that.
borpin
(Brian Orpin)
7 October 2020 06:57
#4
See pinned message
Updated: The latest emonSD image build is now ready.
This image replaces the emonSD-17Oct19 SD card image. This new image includes the latest Raspberry Pi OS and all the latest version of the OpenEnergyMonitor and Emoncms packages, including use of python3 throughout (thanks to @bwduncan , @alexandrecuer and @borpin ).
The image was built using the EmonScripts automated image build script:
github.com/openenergymonitor/EmonScripts
Base image: Raspberry Pi OS (32-bit) Lite 2020-05-27
Image down…
If the card is failing (hence my advice to take a backup urgently), then no, that is the only option.
Anything else is likely to be highly complex.
