Update failing - confused about the "safe-update" list
Really need to list the drives found (if not auto found) and allow that as a parameter to the script.
Good idea I will add that in now
Your post indicates you checked /dev/sda2 which indicates an external device. i.e. your
card and adapter vice the “internal” storage.
Did you reboot after the filesystem error were fixed but before you tried importing again?
169.254.x.x: This is what’s called an Automatic Private IP address. An IP in this range means that the computer cannot see the network. A computer using DHCP needs to have an external server tell it what IP address to use. Unfortunately, if there’s no network connectivity, the computer is unable to talk to the server. In those cases, the computer will actually give itself an IP starting with 169.254, since it must assign itself some sort of number. When you see a 169.254.x.x address, you definitely have a problem. It could be as simple as an unplugged network cable, or it could be as complex as the network being down. A fair amount of troubleshooting is involved at this point, but the bottom line is that your computer doesn’t even see the network.
Ref: What are some IP addresses that might indicate I have a network problem?
A RasPi has no EEPROM, so no danger of that being corrupted.
Have you tried a direct Ethernet connection without your powerline adapters?
We’ve got a pair of them at my workplace, and we’ve observed that while normally fairly reliable,
they can be picky about the hardware connected to them as well as the particular power circuit
they’re used on.
The script now prints out the usb drives that its finds, I’ve updated both the stable and master branches with this change. @Simonsse could you try updating your emonpi and trying the import again?
This is the first part of the result I see:
=== USB Emoncms import start ===
2020-04-29-14:54:33
Backup module version:
    "version"      : "2.2.2"
EUID: 1000
Reading /opt/emoncms/modules/backup/config.cfg....
Location of data databases: /var/opt/emoncms
Location of emonhub.conf: /etc/emonhub
Location of Emoncms: /var/www/emoncms
Scanning for USB card reader:
Found: /dev/disk/by-id/usb-Generic-_SD_MMC_20090815198100000-0:0 at /dev/sda
Using: /dev/disk/by-id/usb-Generic-_SD_MMC_20090815198100000-0:0 at /dev/sda
- No card reader found on sdb
- No card reader found on sdc
Trying the find command
pi@emonpi:~ $ find /dev/disk/by-id/
/dev/disk/by-id/
/dev/disk/by-id/usb-Generic_MassStorageClass_000000001536-0:0-part2
/dev/disk/by-id/usb-Generic_MassStorageClass_000000001536-0:0-part3
/dev/disk/by-id/usb-Generic_MassStorageClass_000000001536-0:0-part1
/dev/disk/by-id/mmc-SC16G_0xb4aaceb9-part3
/dev/disk/by-id/mmc-SC16G_0xb4aaceb9-part2
/dev/disk/by-id/mmc-SC16G_0xb4aaceb9-part1
pi@emonpi:~ $
Did an emonPi update and got your new import script. Update log is
Starting update via service-runner-update.sh (v3.0) >
- emonSD version: emonSD-17Oct19
emonSD base image check passed...continue update
git pull /opt/openenergymonitor/EmonScripts
  master
* stable
On branch stable
Your branch is up to date with 'origin/stable'.
nothing to commit, working tree clean
Already up to date.
Main Update Script
Date: Wed 29 Apr 15:19:16 BST 2020
EUID: 1000
openenergymonitor_dir: /opt/openenergymonitor
type: all
firmware: none
Hardware detected: EmonPi
Stopping emonPiLCD service
Display update message on LCD
I2C LCD DETECTED Ox27
git pull /opt/openenergymonitor/emonpi
* master
On branch master
Your branch is up to date with 'origin/master'.
Fetching origin
Already up to date.
git pull /opt/openenergymonitor/RFM2Pi
* master
On branch master
Fetching origin
Already up to date.
Start emonhub update script:
emonHub update
git pull /opt/openenergymonitor/emonhub
* emon-pi
On branch emon-pi
Your branch is up to date with 'origin/emon-pi'.
Already up to date.
Failed to restart .service.service: Unit .service.service not found.
- Service
Running emonhub automatic node addition script
[[5]]
Node 5 already present
[[6]]
Node 6 already present
[[7]]
Node 7 already present
[[8]]
Node 8 already present
[[9]]
Node 9 already present
[[10]]
Node 10 already present
[[11]]
Node 11 already present
[[12]]
Node 12 already present
[[13]]
Node 13 already present
[[14]]
Node 14 already present
[[15]]
Node 15 already present
[[16]]
Node 16 already present
[[19]]
Node 19 already present
[[20]]
Node 20 already present
[[21]]
Node 21 already present
[[22]]
Node 22 already present
[[23]]
Node 23 already present
[[24]]
Node 24 already present
[[25]]
Node 25 already present
[[26]]
Node 26 already present
Start emoncms update:
Update Emoncms Core
Checking status of /var/www/emoncms git repository
- git branch: stable
- no local changes
- running: git pull origin stable
Fetching origin
From https://github.com/emoncms/emoncms
 * branch              stable     -> FETCH_HEAD
Already up to date.
Update Emoncms database
Update Emoncms Services
emoncms_mqtt.service already installed
feedwriter.service already installed
service-runner.service already installed
Reloading systemctl deamon
Restarting Services...
- sudo systemctl restart feedwriter.service
--- ActiveState=active ---
- sudo systemctl restart emoncms_mqtt.service
- sudo systemctl restart emonhub.service
/opt/openenergymonitor/EmonScripts/sudoers.d/emoncms-rebootbutton: parsed OK
emonPi emoncms admin reboot button sudoers updated
Update Emoncms Modules
Updating /var/www/emoncms/Modules/app module
- git tags: 2.1.1
- no local changes
Fetching origin
Already on 'stable'
Already up to date.
Updating /var/www/emoncms/Modules/config module
- git tags: 2.0.5
- no local changes
Fetching origin
Already on 'stable'
Already up to date.
Updating /var/www/emoncms/Modules/dashboard module
- git tags: 2.0.7
- no local changes
Fetching origin
Already on 'stable'
Already up to date.
Updating /var/www/emoncms/Modules/device module
- git tags: 2.0.5
- no local changes
Fetching origin
Already on 'stable'
Already up to date.
Updating /var/www/emoncms/Modules/graph module
- git tags: 2.0.8-2-g7df046d
- no local changes
Fetching origin
Already on 'stable'
Already up to date.
Updating /var/www/emoncms/Modules/setup module
fatal: No names found, cannot describe anything.
- git tags:
- no local changes
Fetching origin
Already on 'stable'
Already up to date.
Updating /var/www/emoncms/Modules/wifi module
- git tags: 2.0.0-29-g274bcd5
- no local changes
Fetching origin
Already on 'stable'
Already up to date.
/opt/openenergymonitor/EmonScripts/sudoers.d/wifi-sudoers: parsed OK
wifi sudoers entry updated
Updating /opt/emoncms/modules/backup module
- git tags: 2.2.2
- no local changes
From https://github.com/emoncms/backup
   8b670a0..70894e1  stable     -> origin/stable
   dfaca67..3f2beaa  master     -> origin/master
Updating 8b670a0..70894e1
Fast-forward
 .travis.yml               |  14 ++
 LICENSE.txt               | 619 ++++++++++++++++++++++++++++++++++++++++++++++
 backup-module/module.json |   2 +-
 composer.json             |  17 ++
 usb-import.sh             |  15 +-
 5 files changed, 658 insertions(+), 9 deletions(-)
 create mode 100644 .travis.yml
 create mode 100644 LICENSE.txt
 create mode 100644 composer.json
Already on 'stable'
Updating /opt/emoncms/modules/demandshaper module
- git tags: 1.2.4-5-gd689aae
- no local changes
Already up to date.
Already on 'stable'
Updating /opt/emoncms/modules/postprocess module
- git tags: 2.1.0-21-g0e2d78f
- no local changes
Already up to date.
Already on 'stable'
Updating /opt/emoncms/modules/sync module
- git tags: 2.0.5
- no local changes
Already up to date.
Already on 'stable'
Updating /opt/emoncms/modules/usefulscripts module
- git tags:
- no local changes
Already up to date.
Already on 'stable'
Backup module installation and update script
- Loading EmonScripts config.ini
- Copying default.config.cfg to config.cfg
- Setting config.cfg settings
- Backup module symlink already exists
- PHP Version: 7.3
- Creating /etc/php/7.3/mods-available/emoncmsbackup.ini
post_max_size = 3G
upload_max_filesize = 3G
upload_tmp_dir = /var/opt/emoncms/backup/uploads
- phpenmod emoncmsbackup
- /var/opt/emoncms/backup already exists
- /var/opt/emoncms/backup/uploads already exists
- restarting apache
Starting emonPi LCD service..
emonPi update done: Wed 29 Apr 15:20:03 BST 2020
restarting service-runner
Ran it and it did lots of work
2020-04-29-15:20:13
    "version"      : "2.2.3"
EUID: 1000
- Found: /dev/disk/by-id/usb-Generic_MassStorageClass_000000001536-0:0 at /dev/sda
**Using: /dev/disk/by-id/usb-Generic_MassStorageClass_000000001536-0:0 at /dev/sda**
creating mount point /media/old_sd_boot
creating mount point /media/old_sd_root
creating mount point /media/old_sd_data
Mounting old SD card boot partition
Mounting old SD card root partition
Mounting old SD card data partition
Stopping services..
Read MYSQL authentication details from settings.php
stopping mysql
Manually deleting old mysql emoncms database
Manual install of emoncms database
'/media/old_sd_root/var/lib/mysql/emoncms' -> '/var/lib/mysql/emoncms'
'/media/old_sd_root/var/lib/mysql/emoncms/db.opt' -> '/var/lib/mysql/emoncms/db.opt'
'/media/old_sd_root/var/lib/mysql/emoncms/app_config.frm' -> '/var/lib/mysql/emoncms/app_config.frm'
'/media/old_sd_root/var/lib/mysql/emoncms/app_config.MYI' -> '/var/lib/mysql/emoncms/app_config.MYI'
'/media/old_sd_root/var/lib/mysql/emoncms/app_config.MYD' -> '/var/lib/mysql/emoncms/app_config.MYD'
'/media/old_sd_root/var/lib/mysql/emoncms/demandshaper.frm' -> '/var/lib/mysql/emoncms/demandshaper.frm'
'/media/old_sd_root/var/lib/mysql/emoncms/demandshaper.MYI' -> '/var/lib/mysql/emoncms/demandshaper.MYI'
'/media/old_sd_root/var/lib/mysql/emoncms/demandshaper.MYD' -> '/var/lib/mysql/emoncms/demandshaper.MYD'
'/media/old_sd_root/var/lib/mysql/emoncms/device.frm' -> '/var/lib/mysql/emoncms/device.frm'
'/media/old_sd_root/var/lib/mysql/emoncms/device.MYI' -> '/var/lib/mysql/emoncms/device.MYI'
'/media/old_sd_root/var/lib/mysql/emoncms/device.MYD' -> '/var/lib/mysql/emoncms/device.MYD'
'/media/old_sd_root/var/lib/mysql/emoncms/feeds.frm' -> '/var/lib/mysql/emoncms/feeds.frm'
'/media/old_sd_root/var/lib/mysql/emoncms/feeds.MYI' -> '/var/lib/mysql/emoncms/feeds.MYI'
'/media/old_sd_root/var/lib/mysql/emoncms/feeds.MYD' -> '/var/lib/mysql/emoncms/feeds.MYD'
'/media/old_sd_root/var/lib/mysql/emoncms/graph.frm' -> '/var/lib/mysql/emoncms/graph.frm'
'/media/old_sd_root/var/lib/mysql/emoncms/graph.MYI' -> '/var/lib/mysql/emoncms/graph.MYI'
'/media/old_sd_root/var/lib/mysql/emoncms/graph.MYD' -> '/var/lib/mysql/emoncms/graph.MYD'
'/media/old_sd_root/var/lib/mysql/emoncms/input.frm' -> '/var/lib/mysql/emoncms/input.frm'
'/media/old_sd_root/var/lib/mysql/emoncms/input.MYI' -> '/var/lib/mysql/emoncms/input.MYI'
'/media/old_sd_root/var/lib/mysql/emoncms/input.MYD' -> '/var/lib/mysql/emoncms/input.MYD'
'/media/old_sd_root/var/lib/mysql/emoncms/postprocess.frm' -> '/var/lib/mysql/emoncms/postprocess.frm'
'/media/old_sd_root/var/lib/mysql/emoncms/postprocess.MYI' -> '/var/lib/mysql/emoncms/postprocess.MYI'
'/media/old_sd_root/var/lib/mysql/emoncms/postprocess.MYD' -> '/var/lib/mysql/emoncms/postprocess.MYD'
'/media/old_sd_root/var/lib/mysql/emoncms/schedule.frm' -> '/var/lib/mysql/emoncms/schedule.frm'
'/media/old_sd_root/var/lib/mysql/emoncms/schedule.MYI' -> '/var/lib/mysql/emoncms/schedule.MYI'
'/media/old_sd_root/var/lib/mysql/emoncms/schedule.MYD' -> '/var/lib/mysql/emoncms/schedule.MYD'
'/media/old_sd_root/var/lib/mysql/emoncms/setup.frm' -> '/var/lib/mysql/emoncms/setup.frm'
'/media/old_sd_root/var/lib/mysql/emoncms/setup.MYI' -> '/var/lib/mysql/emoncms/setup.MYI'
'/media/old_sd_root/var/lib/mysql/emoncms/setup.MYD' -> '/var/lib/mysql/emoncms/setup.MYD'
'/media/old_sd_root/var/lib/mysql/emoncms/sync.frm' -> '/var/lib/mysql/emoncms/sync.frm'
'/media/old_sd_root/var/lib/mysql/emoncms/sync.MYI' -> '/var/lib/mysql/emoncms/sync.MYI'
'/media/old_sd_root/var/lib/mysql/emoncms/sync.MYD' -> '/var/lib/mysql/emoncms/sync.MYD'
'/media/old_sd_root/var/lib/mysql/emoncms/users.frm' -> '/var/lib/mysql/emoncms/users.frm'
'/media/old_sd_root/var/lib/mysql/emoncms/users.MYI' -> '/var/lib/mysql/emoncms/users.MYI'
'/media/old_sd_root/var/lib/mysql/emoncms/users.MYD' -> '/var/lib/mysql/emoncms/users.MYD'
'/media/old_sd_root/var/lib/mysql/emoncms/rememberme.frm' -> '/var/lib/mysql/emoncms/rememberme.frm'
'/media/old_sd_root/var/lib/mysql/emoncms/rememberme.MYI' -> '/var/lib/mysql/emoncms/rememberme.MYI'
'/media/old_sd_root/var/lib/mysql/emoncms/rememberme.MYD' -> '/var/lib/mysql/emoncms/rememberme.MYD'
'/media/old_sd_root/var/lib/mysql/emoncms/multigraph.frm' -> '/var/lib/mysql/emoncms/multigraph.frm'
'/media/old_sd_root/var/lib/mysql/emoncms/multigraph.MYI' -> '/var/lib/mysql/emoncms/multigraph.MYI'
'/media/old_sd_root/var/lib/mysql/emoncms/multigraph.MYD' -> '/var/lib/mysql/emoncms/multigraph.MYD'
'/media/old_sd_root/var/lib/mysql/emoncms/dashboard.frm' -> '/var/lib/mysql/emoncms/dashboard.frm'
'/media/old_sd_root/var/lib/mysql/emoncms/dashboard.MYI' -> '/var/lib/mysql/emoncms/dashboard.MYI'
'/media/old_sd_root/var/lib/mysql/emoncms/dashboard.MYD' -> '/var/lib/mysql/emoncms/dashboard.MYD'
Setting database ownership
starting mysql
checking database
emoncms.app_config                                 OK
emoncms.dashboard                                  OK
emoncms.demandshaper                               OK
emoncms.device                                     OK
emoncms.feeds                                      OK
emoncms.graph                                      OK
emoncms.input                                      OK
emoncms.multigraph                                 OK
emoncms.postprocess                                OK
emoncms.rememberme                                 OK
emoncms.schedule                                   OK
emoncms.setup                                      OK
emoncms.sync                                       OK
emoncms.users                                      OK
Updating Emoncms Database..
Archive old data folders
Copying PHPFina feed data
'/media/old_sd_data/phpfina' -> '/var/opt/emoncms/phpfina'
'/media/old_sd_data/phpfina/1.meta' -> '/var/opt/emoncms/phpfina/1.meta'
'/media/old_sd_data/phpfina/1.dat' -> '/var/opt/emoncms/phpfina/1.dat'
'/media/old_sd_data/phpfina/4.meta' -> '/var/opt/emoncms/phpfina/4.meta'
'/media/old_sd_data/phpfina/4.dat' -> '/var/opt/emoncms/phpfina/4.dat'
'/media/old_sd_data/phpfina/3.meta' -> '/var/opt/emoncms/phpfina/3.meta'
'/media/old_sd_data/phpfina/3.dat' -> '/var/opt/emoncms/phpfina/3.dat'
'/media/old_sd_data/phpfina/5.meta' -> '/var/opt/emoncms/phpfina/5.meta'
'/media/old_sd_data/phpfina/5.dat' -> '/var/opt/emoncms/phpfina/5.dat'
'/media/old_sd_data/phpfina/6.meta' -> '/var/opt/emoncms/phpfina/6.meta'
'/media/old_sd_data/phpfina/6.dat' -> '/var/opt/emoncms/phpfina/6.dat'
'/media/old_sd_data/phpfina/7.meta' -> '/var/opt/emoncms/phpfina/7.meta'
'/media/old_sd_data/phpfina/7.dat' -> '/var/opt/emoncms/phpfina/7.dat'
'/media/old_sd_data/phpfina/8.meta' -> '/var/opt/emoncms/phpfina/8.meta'
'/media/old_sd_data/phpfina/8.dat' -> '/var/opt/emoncms/phpfina/8.dat'
'/media/old_sd_data/phpfina/9.meta' -> '/var/opt/emoncms/phpfina/9.meta'
'/media/old_sd_data/phpfina/9.dat' -> '/var/opt/emoncms/phpfina/9.dat'
'/media/old_sd_data/phpfina/14.meta' -> '/var/opt/emoncms/phpfina/14.meta'
'/media/old_sd_data/phpfina/15.meta' -> '/var/opt/emoncms/phpfina/15.meta'
'/media/old_sd_data/phpfina/14.dat' -> '/var/opt/emoncms/phpfina/14.dat'
'/media/old_sd_data/phpfina/15.dat' -> '/var/opt/emoncms/phpfina/15.dat'
'/media/old_sd_data/phpfina/16.meta' -> '/var/opt/emoncms/phpfina/16.meta'
'/media/old_sd_data/phpfina/16.dat' -> '/var/opt/emoncms/phpfina/16.dat'
Copying PHPTimeSeries feed data
'/media/old_sd_data/phptimeseries' -> '/var/opt/emoncms/phptimeseries'
'/media/old_sd_root/etc/emonhub/emonhub.conf' -> '/etc/emonhub/emonhub.conf'
Flushing redis
OK
Restarting emonhub...
Restarting feedwriter...
Restarting emoncms MQTT...
2020-04-29-15:21:03
=== Emoncms import complete! ===
So I’ve rebooted. Deep breath, refresh the browser on the emonPi and …
I’m back! All previously recorded data restored.
Thank you Trystan, much appreciate the instant responses today, and glad to have been able to provide material to improve the product.
Apologies for the off topic comments below, I’ll happily repost appropriately if you recommend so.
  1. There is a ca. 2 day data gap which the My Solar App shows as constant use rather than My Electric showing zero, which IMHO would be better.
  2. I suspect that the old SDcard will be absolutely fine for reuse - or for the few pounds cost should I just ditch it as suspect and tainted?
  3. I will repost on the wired ethernet in another forum section - clearly nothing to do with emonSD.
@borpin I also have eth0 and wlan0 IPs. And had a play with dhcpcd.conf to try and assign a valid local wired network IP, to no avail. Efforts to sort were pushed to the back of the queue when all started falling apart.
@Bill.Thomson I will try without the powerline adapters - I too have found them flaky. Had a big win when I realised the out of the box setup with default credentials was locking on to somebody else’s adapter on the same power phase (a neighbour somewhere). Changed the authorisation and its been much more stable for many months.
@borpin So what was the history here of emonCMS earlier with, and now without node-red? What happened to take it out of the default SDcard build for emonPi, and why would you not run NR on the same box as emonPi. Also why do you say elsewhere that Home Assistant beats EmonCMS in some corners of the automation market? Would you also suggest HA should have its own Pi?
My interest in NR is first to record and display number of my SolaX X1-Hybrid PV inverter and battery storage system at finer granularity than I can get from the SolaX Cloud (ca. 5 min update periods). I see traffic on this forum about SolaX connectivity through the X1-Hybrid’s WiFi port which can report all the inverter stats, and there is a NR flow to parse these into MQTT to feed into emonCMS, where I plan to record data and build some dashboard(s).
In the fullness of time I would also like to add in charging control - ideally enabling the export of battery power to the grid, this preferably being in late afternoon as I am on Octopus Agile Outgoing, where export rates up to 30p/kWh are on offer in the 1600-1900 afternoon slots.
I am also interested in automating the house’s heating, taking in to account near future expectations of which rooms will be in use, external temperatures, costs of energy (in CO2e and £), etc, etc.
A pointer to a emonPi, EmonCMS, Home Assistant, Node-Red, … comparison would be helpful.
Many thanks
I would second Brian’s suggestion to run Node-Red on a second Pi. I didn’t used to and it caused a lot of grief when things went wrong (like a failed SD card… sound familiar?)
Since using a second Pi for mosquitto and NR any problems have been much easier to deal with.
An early release of the emonCMS image included Node-RED. Node-RED is a little notorious when trying to keep it up to date (though it is better now) and having somethign else on the emonCMS system can cause issues as the layout of the partitions etc is optimised to prolong the life of the SD Card. Adding things to that, can have unexpected consequences ( as you may or may not have discovered).
HA has a mass of automation options and you can build very complex relationships between things. emonCMS will never be able to compete on that front. However, emonCMS does have some specialised automation systems (like demandshaper). HA does have a fairly steep learning curve! I use HA to control my heating and more recently my hot water (4 separate temp sensors rather than a single ‘thermostat’).
Personally, I run a supervised install of HA on a Pi4-4Gb. There is an add-on to run Node-RED inside HA effectively and I use that for my main Node-RED instance. If you do go down this road, I suggest a HDD or SDD and probably the prebuilt image. In the future I will look to move HA onto an NUC as I feel that will be more reliable and robust.
