Hi!
I am looking at setting up emonPis in WIFI networks that require username and passwords to log in (e.g. campus network). Is there a possibility to do something like that, maybe by hardcoding the setup in wpa_supplicant.conf, or do I need to create my own (mobile) WIFI network?
Thanks!
Marcel
Hi Marcel,
Do you mean that your wifi networks require some sort of captive portal login authentication via a web page after connection to the network? If so, this is tricky. I’m not sure it’s possible. Your best bet would be to take a look on the RasPi forums for a solution or connect via Ethernet.
Sure, it’s possible to connect via SSH and modify wpa_supplicant.conf on the emonPi but I think this may not be enough to obtain connection to your network.
Hi Glyn,
Not quite, it’s not with a captive portal login authentication but rather username/password combination on a university network. Thanks for your suggestion - the keywords helped me find more information.
This answer looks most plausible but haven’t been able to test myself yet. I will comment again once I have tried it: http://raspberrypi.stackexchange.com/questions/43359/connecting-to-universities-wpa2-enterprise-wifi-network/43400#43400
Hi Glyn
It’s a bit late but I finally tested the suggested solution in the link I found. It was a little different, especially because I did not need a certificate. Found the solution through various places in the end. The following solution has by now worked in multiple locations:
Change interfaces file:
sudo nano /etc/network/interfaces
# interfaces(5) file used by ifup(8) and ifdown(8)
# Please note that this file is written to be used with dhcpcd
# For static IP, consult /etc/dhcpcd.conf and 'man dhcpcd.conf'
# Include files from /etc/network/interfaces.d:
source-directory /etc/network/interfaces.d
auto lo
iface lo inet loopback
iface eth0 inet dhcp
allow-hotplug wlan0
iface wlan0 inet dhcp
pre-up wpa_supplicant -B -Dwext -i wlan0 -c/etc/wpa_supplicant/wpa_supplicant.conf
post-down killall -q wpa_supplicant
Then change the config file to have network name and login details hardcoded:
sudo nano /etc/wpa_supplicant/wpa_supplicant.conf
ctrl_interface=DIR=/var/run/wpa_supplicant GROUP=netdev
update_config=1
network={
ssid="MyUniversityNetwork (e.g. eduroam)"
scan_ssid=1
key_mgmt=WPA-EAP
pairwise=CCMP TKIP
group=CCMP TKIP
eap=PEAP
identity="MyLoginName"
password="MyPassword"
phase1="peapver=0"
phase2="MSCHAPV2"
I hope this will help somebody else.
Cheers Marcel
Nice! Thanks for sharing
