Hello @fba, The units for the power field are in Watts. You can convert to a cumulative kWh feed using the power_to_kwh process in emoncms. Are you using emoncms?
Thanks @TrystanLea,
in this moment I’m not using the emoncms because I wanted to read the value directly.
I will try both solutions.
For use the emoncms I must create a log to feed like 1° step and Power to kWh like 2° step?
In this way I have the consume instant time?
