Uncaught reference error list format updated object
Suddenly after upgrade I get an error popup displaying Uncaught reference error list format updated object when clicking on inputs. (route: input/view) Line 910 column 22)
Should I re-flash EmonPI. (Where is SD slot in an emonPI bought from the shop?)
The last log messages:
2019-06-27 21:42:36.772|WARN|emoncms_mqtt.php|Connecting to MQTT server: Connection Accepted.: code: 0
2019-06-27 21:50:56.402|ERROR|emoncms_mqtt.php|ErrorException: Undefined index: nodeid in /var/www/emoncms/Modules/input/input_model.php:206
Stack trace:
#0 /var/www/emoncms/Modules/input/input_model.php(206): exceptions_error_handler(8, 'Undefined index...', '/var/www/emoncm...', 206, Array)
#1 /var/www/emoncms/Modules/input/input_model.php(183): Input->redis_get_inputs(1)
#2 /var/www/emoncms/scripts/services/emoncms_mqtt/emoncms_mqtt.php(308): Input->get_inputs(1)
#3 [internal function]: message(Object(Mosquitto\Message))
#4 /var/www/emoncms/scripts/services/emoncms_mqtt/emoncms_mqtt.php(130): Mosquitto\Client->loop()
#5 {main}
2019-06-27 21:50:56.406|ERROR|emoncms_mqtt.php|ErrorException: Undefined index: nodeid in /var/www/emoncms/Modules/input/input_model.php:206
Stack trace:
#5 {main}
2019-06-27 21:50:56.410|ERROR|emoncms_mqtt.php|ErrorException: Undefined index: nodeid in /var/www/emoncms/Modules/input/input_model.php:206
Stack trace:
#5 {main}
Can you go into the Admin page and where you see Server Information click on Copy as Markdown and paste that here (no further formatting required). please?
Server Information
Server Information
Services
  • emonhub :- Active Running
  • emoncms_mqtt :- Active Running
  • feedwriter :- Active Running - sleep 60s 16 feed points pending write
  • service-runner :- Active Running
  • emonPiLCD :- Active Running
  • redis-server :- Active Running
  • mosquitto :- Active Running
Emoncms
Server
  • OS :- Linux 4.14.71-v7+
  • Host :- emonpi | emonpi | (192.168.0.154)
  • Date :- 2019-06-28 06:42:28 UTC
  • Uptime :- 06:42:28 up 10:36, 0 users, load average: 0.16, 0.17, 0.12
Memory
  • RAM :- Used: 18.63%
    • Total :- 976.74 MB
    • Used :- 181.92 MB
    • Free :- 794.82 MB
  • Swap :- Used: 0.00%
    • Total :- 100 MB
    • Used :- 0 B
    • Free :- 100 MB
Disk
  • / :- Used: 41.79%
    • Total :- 3.81 GB
    • Used :- 1.59 GB
    • Free :- 2.04 GB
  • /home/pi/data :- Used: 1.09%
    • Total :- 10.32 GB
    • Used :- 114.98 MB
    • Free :- 9.68 GB
  • /boot :- Used: 51.69%
    • Total :- 42.52 MB
    • Used :- 21.98 MB
    • Free :- 20.54 MB
HTTP
  • Server :- Apache/2.4.25 (Raspbian) HTTP/1.1 CGI/1.1 80
MySQL
  • Version :- 5.5.5-10.1.23-MariaDB-9+deb9u1
  • Host :- localhost:6379 (127.0.0.1)
  • Date :- 2019-06-28 06:42:27 (UTC 00:00‌​)
  • Stats :- Uptime: 38204 Threads: 3 Questions: 37088 Slow queries: 0 Opens: 74 Flush tables: 1 Open tables: 22 Queries per second avg: 0.970
Redis
  • Version :- 3.2.6
  • Size :- 105 keys (813.10K)
  • Uptime :- 0 days
MQTT Server
  • Version :- Mosquitto 1.4.10
  • Host :- localhost:1883 (127.0.0.1)
PHP
  • Version :- 7.0.33-0+deb9u3 (Zend Version 3.0.0)
  • Modules :- apache2handler | bz2 v7.0.33-0+deb9u3 | calendar v7.0.33-0+deb9u3 | Core v7.0.33-0+deb9u3 | ctype v7.0.33-0+deb9u3 | curl v7.0.33-0+deb9u3 | date v7.0.33-0+deb9u3 | dom v20031129 | exif v7.0.33-0+deb9u3 | fileinfo v1.0.5 | filter v7.0.33-0+deb9u3 | ftp v7.0.33-0+deb9u3 | gd v7.0.33-0+deb9u3 | gettext v7.0.33-0+deb9u3 | hash v1.0 | iconv v7.0.33-0+deb9u3 | igbinary v2.0.1 | json v1.4.0 | libxml v7.0.33-0+deb9u3 | mbstring v7.0.33-0+deb9u3 | mcrypt v7.0.33-0+deb9u3 | mosquitto v0.4.0 | mysqli v7.0.33-0+deb9u3 | mysqlnd vmysqlnd 5.0.12-dev - 20150407 - Id: b5c5906d452ec590732a93b051f3827e02749b83 | openssl v7.0.33-0+deb9u3 | pcre v7.0.33-0+deb9u3 | PDO v7.0.33-0+deb9u3 | pdo_mysql v7.0.33-0+deb9u3 | Phar v2.0.2 | posix v7.0.33-0+deb9u3 | readline v7.0.33-0+deb9u3 | redis v4.1.1 | Reflection v7.0.33-0+deb9u3 | session v7.0.33-0+deb9u3 | shmop v7.0.33-0+deb9u3 | SimpleXML v7.0.33-0+deb9u3 | sockets v7.0.33-0+deb9u3 | SPL v7.0.33-0+deb9u3 | standard v7.0.33-0+deb9u3 | sysvmsg v7.0.33-0+deb9u3 | sysvsem v7.0.33-0+deb9u3 | sysvshm v7.0.33-0+deb9u3 | tokenizer v7.0.33-0+deb9u3 | wddx v7.0.33-0+deb9u3 | xml v7.0.33-0+deb9u3 | xmlreader v7.0.33-0+deb9u3 | xmlwriter v7.0.33-0+deb9u3 | xsl v7.0.33-0+deb9u3 | Zend OPcache v7.0.33-0+deb9u3 | zip v1.13.5 | zlib v7.0.33-0+deb9u3
Pi
  • Model :- Raspberry Pi 3 Model B+ Rev 1.3 - 1 GB (Sony UK)
  • SoC :- Broadcom BCM2835
  • Serial num. :- 4ACF3CC1
  • Temperature :- 42.39°C - 42.9°C
  • emonpiRelease :- emonSD-30Oct18
  • File-system :- read-write
Client Information
Client Information
HTTP
  • Browser :- Mozilla/5.0 (Macintosh; Intel Mac OS X 10_14_5) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/75.0.3770.80 Safari/537.36
  • Language :- nl-NL,nl;q=0.9,en-US;q=0.8,en;q=0.7,de;q=0.6
Window
  • Size :- 2224 x 1249
Screen
  • Resolution :- 2560 x 1440
I’m slightly confused by this information
Could you run a full update again and then refresh the admin page please?
After the upgrade it still says low-write…
Update log:
Server Information
Server Information
Services
Emoncms
Server
Memory
    • Used :- 181.92 MB
    • Free :- 794.82 MB
    • Total :- 100 MB
    • Used :- 0 B
    • Free :- 100 MB
Disk
  • / :- Used: 41.79%
    • Total :- 3.81 GB
    • Used :- 1.59 GB
    • Free :- 2.04 GB
    • Total :- 10.32 GB
    • Used :- 114.98 MB
    • Free :- 9.68 GB
    • Total :- 42.52 MB
    • Used :- 21.98 MB
    • Free :- 20.54 MB
HTTP
MySQL
Redis
  • Version :- 3.2.6
  • Uptime :- 0 days
MQTT Server
PHP
Pi
Client Information
Client Information
HTTP
Window
Screen
LAST ENTRIES ON THE LOG FILE
Starting update via service-runner-update.sh (v2.0) >
- emonSD version: emonSD-30Oct18
emonSD base image check passed...continue update
git pull /home/pi/emonpi
enable-ssh
enable-ssh-button
gpiozero-enable-ssh
greeebs-patch-1
* master
python-systemd-servicerunner
On branch master
Your branch is up-to-date with 'origin/master'.
nothing to commit, working tree clean
Already up-to-date.
Main Update Script
Date: [Fri 28 Jun 06:52:01 UTC](http://airmail.calendar/2019-06-28%2008:52:01%20CEST) 2019
EUID: 1000
usrdir: /home/pi
type: all
firmware: emonpi
Checking environment:
- pi user found
EUID: 1000
Hardware detected: EmonPi
Stopping emonPiLCD service
Display update message on LCD
I2C LCD DETECTED Ox27
Hit:1 http://archive.raspberrypi.org/debian stretch InRelease
Get:2 http://raspbian.raspberrypi.org/raspbian stretch InRelease [15.0 kB]
Fetched 15.0 kB in 0s (15.6 kB/s)
Reading package lists...
Building dependency tree...
Reading state information...
rng-tools is already the newest version (2-unofficial-mt.14-1).
python-gpiozero is already the newest version (1.5.0).
python-rpi.gpio is already the newest version (0.6.5~stretch-1).
0 upgraded, 0 newly installed, 0 to remove and 107 not upgraded.
Requirement already up-to-date: paho-mqtt in /usr/local/lib/python2.7/dist-packages
git pull /home/pi/RFM2Pi
* master
On branch master
Already up-to-date.
git pull /home/pi/usefulscripts
* master
On branch master
Already up-to-date.
git pull /home/pi/huawei-hilink-status
* master
On branch master
Already up-to-date.
git pull /home/pi/oem_node-red
* master
On branch master
Already up-to-date.
EmonPi Firmware Update
Start ATmega328 serial upload using avrdude with latest.hex
Discrete Sampling
avrdude -c arduino -p ATMEGA328P -P /dev/ttyAMA0 -b 115200 -U flash:w:/home/pi/emonpi/firmware/compiled/latest.hex
avrdude-original: Using autoreset DTR on GPIO Pin 7
avrdude-original: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude-original: Device signature = 0x1e950f (probably m328p)
avrdude-original: NOTE: "flash" memory has been specified, an erase cycle will be performed
To disable this feature, specify the -D option.
avrdude-original: erasing chip
avrdude-original: reading input file "/home/pi/emonpi/firmware/compiled/latest.hex"
avrdude-original: input file /home/pi/emonpi/firmware/compiled/latest.hex auto detected as Intel Hex
avrdude-original: writing flash (17886 bytes):
Writing | ################################################## | 100% 2.49s
avrdude-original: 17886 bytes of flash written
avrdude-original: verifying flash memory against /home/pi/emonpi/firmware/compiled/latest.hex:
avrdude-original: load data flash data from input file /home/pi/emonpi/firmware/compiled/latest.hex:
avrdude-original: input file /home/pi/emonpi/firmware/compiled/latest.hex contains 17886 bytes
avrdude-original: reading on-chip flash data:
Reading | ################################################## | 100% 1.87s
avrdude-original: verifying ...
avrdude-original: 17886 bytes of flash verified
strace: |autoreset: Broken pipe
avrdude-original done. Thank you.
Start emonhub update script:
emonHub update started
- usr directory: /home/pi
git pull /home/pi/emonhub
* emon-pi
On branch emon-pi
Your branch is up-to-date with 'origin/emon-pi'.
Untracked files:
(use "git add ..." to include in what will be committed)
src/src
nothing added to commit but untracked files present (use "git add" to track)
Already up-to-date.
Creating emonhub logfile
Symlinking emonhub.conf to /etc/emonhub/emonhub.conf
emonhub.service already installed
Running emonhub automatic node addition script
[[5]]
Node 5 already present
[[6]]
Node 6 already present
[[7]]
Node 7 already present
[[8]]
Node 8 already present
[[9]]
Node 9 already present
[[10]]
Node 10 already present
[[11]]
Node 11 already present
[[12]]
Node 12 already present
[[13]]
Node 13 already present
[[14]]
Node 14 already present
[[19]]
Node 19 already present
[[20]]
Node 20 already present
[[21]]
Node 21 already present
[[22]]
Node 22 already present
[[23]]
Node 23 already present
[[24]]
Node 24 already present
[[25]]
Node 25 already present
[[26]]
Node 26 already present
Start emoncms update:
Emoncms update started
Emoncms update script V1.3 ([26th March 2019](http://airmail.calendar/2019-03-26%2012:00:00%20CET))
- emoncms directory: /var/www/emoncms
current settings.php md5: 0e4803a641b7784ed23edf87506ce761
Default settings.php md5: 0e4803a641b7784ed23edf87506ce761
settings.php has NOT been user modifed
Checking status of /var/www/emoncms git repository
- git branch: stable
- no local changes
- running: git pull origin stable
From https://github.com/emoncms/emoncms
* branch stable -> FETCH_HEAD
*** Please tell me who you are.
Run
git config --global user.email "[[email protected]](mailto:[email protected])"
git config --global [user.name](http://user.name/) "Your Name"
to set your account's default identity.
Omit --global to set the identity only in this repository.
fatal: empty ident name (for <(null)>) not allowed
NEW default settings.php md5: 0e4803a641b7784ed23edf87506ce761
settings.php not updated
Updating Emoncms Modules
Updating /var/www/emoncms/Modules/app module
- git tags: 1.2.0-108-g6e5016a
- no local changes
From https://github.com/emoncms/app
Already up-to-date.
Updating /var/www/emoncms/Modules/config module
- git tags: 1.0.0-63-g1d9238e
- no local changes
From https://github.com/emoncms/config
Already up-to-date.
Updating /var/www/emoncms/Modules/dashboard module
- git tags: 1.3.1-134-g337df80
- no local changes
From https://github.com/emoncms/dashboard
Already up-to-date.
Updating /var/www/emoncms/Modules/device module
- git branch: master
- git tags: 1.1.1-48-g2ea6e74
- no local changes
- running: git pull origin master
From https://github.com/emoncms/device
* branch master -> FETCH_HEAD
Already up-to-date.
Updating /var/www/emoncms/Modules/graph module
- git tags: 1.2.1-151-gc7f4ea9
- no local changes
From https://github.com/emoncms/graph
Already up-to-date.
Updating /var/www/emoncms/Modules/wifi module
- git tags: 1.2.0-39-gb67783d
- no local changes
From https://github.com/emoncms/wifi
Already up-to-date.
Updating postprocess module
- git branch: emonpi
- git tags: 2.1.0-1-g1d25eb6
- no local changes
- running: git pull origin emonpi
Already up-to-date.
Already on 'emonpi'
Your branch is up-to-date with 'origin/emonpi'.
Updating sync module
- git tags: 2.0.1-8-g3ae3226
- no local changes
Already up-to-date.
Already on 'master'
Updating backup module
- git tags: 2.0.0-12-g67a1f1d
- no local changes
Already up-to-date.
Already on 'stable'
Your branch is up-to-date with 'origin/stable'.
Auto Installation of Emoncms Modules
- graph module already installed
- device module already installed
- postprocess module already installed
- sync module already installed
- backup module already installed
www-data : www-data video systemd-journal
SERVICES
emoncms_mqtt.service already installed
feedwriter.service already installed
service-runner.service already installed
Reloading systemctl deamon
Update Emoncms database
Restarting Services...
- sudo systemctl restart feedwriter.service
--- ActiveState=active ---
- sudo systemctl restart emoncms_mqtt.service
- sudo systemctl restart emonhub.service
Symlinking emonpiupdate.log
Installing emoncms logrotate...
Now setting up Logrotate...
Backing up old logrotate configuration...
Linked to new logrotate configuration...
Backing up old logrotate cron job...
mv: cannot stat '/etc/cron.daily/logrotate': No such file or directory
Linked to new logrotate cron job...
Completed
Completed
Running logrotate...
set log rotate config owner to root
Emoncms update script complete
Starting emonPi LCD service..
emonPi update done: [Fri 28 Jun 06:52:57 UTC](http://airmail.calendar/2019-06-28%2008:52:57%20CEST) 2019
restarting service-runner
service-runner: no process found
Can you SSH into the EmonPi?
yes i can
Ok great, If you SSH in then
cd /var/www/emoncms
git describe --debug
git status
please.
It looks like git has got confused somehow.
git discribe: 10.1.1-1-g2497fd29
git status
On branch stable
Your branch and 'origin/stable' have diverged,
and have 1 and 2 different commits each, respectively.
  (use "git pull" to merge the remote branch into yours)
Ok. Have you made any changes you know of to the code (I suspect not)?
If not run these commands
sudo git reset --hard
sudo git fetch --all --prune -v
No, i did not change the code.
DO I need to update again now?
It is still displaying :- low-write 10.1.2-beta
If you have run those commands then no. Refresh the admin page and post the output again please.
Has the error gone?
The error is still there
Server Information
Server Information
Services
  • feedwriter :- Active Running - sleep 60s 40 feed points pending write
Emoncms
Server
  • Date :- 2019-06-28 07:11:23 UTC
  • Uptime :- 07:11:23 up 11:05, 1 user, load average: 0.09, 0.06, 0.08
Memory
  • RAM :- Used: 19.35%
    • Used :- 188.96 MB
    • Free :- 787.78 MB
    • Total :- 100 MB
    • Used :- 0 B
    • Free :- 100 MB
Disk
  • / :- Used: 41.79%
    • Total :- 3.81 GB
    • Used :- 1.59 GB
    • Free :- 2.04 GB
    • Total :- 10.32 GB
    • Used :- 114.99 MB
    • Free :- 9.68 GB
    • Total :- 42.52 MB
    • Used :- 21.98 MB
    • Free :- 20.54 MB
HTTP
MySQL
  • Date :- 2019-06-28 07:11:23 (UTC 00:00‌​)
  • Stats :- Uptime: 39939 Threads: 4 Questions: 39198 Slow queries: 0 Opens: 79 Flush tables: 1 Open tables: 27 Queries per second avg: 0.981
Redis
  • Version :- 3.2.6
  • Size :- 126 keys (782.74K)
  • Uptime :- 0 days
MQTT Server
PHP
Pi
  • Temperature :- 45.08°C - 45.1°C
Client Information
Client Information
HTTP
Window
Screen
Fetching origin
From GitHub - emoncms/emoncms: Web-app for processing, logging and visualising energy, temperature and other environmental data
  • [deleted] (none) → origin/low-write
  • [deleted] (none) → origin/pb66-patch-1
  • [deleted] (none) → origin/pb66-patch-2
  • [deleted] (none) → origin/pb66-patch-3
  • [deleted] (none) → origin/systmdRunner
    = [up to date] stable → origin/stable
    = [up to date] data_checker → origin/data_checker
    = [up to date] hierarchical_settings_php → origin/hierarchical_settings_php
    = [up to date] indexedinputs → origin/indexedinputs
    = [up to date] input_vue_test → origin/input_vue_test
    = [up to date] logrotate → origin/logrotate
    = [up to date] master → origin/master
    = [up to date] mqtt → origin/mqtt
    = [up to date] mqttauth → origin/mqttauth
    = [up to date] pb66-patch-1-1 → origin/pb66-patch-1-1
    = [up to date] pb66-patch-phpmqtt_input → origin/pb66-patch-phpmqtt_input
    = [up to date] restructure → origin/restructure
Ah sorry, from the command line run
sudo git pull
and post the output please. When posting output if you put 3 backticks (found in the top left of the keyboard next to ‘1’) on a line before the output and 3 on a line after, it will format correctly.
Already up-to-date
(it needs to be the backtick not the apostrophe to format correctly - top left of keyboard usually)
Odd.
Can you do
sudo git show
please
commit 03b8c60517eb70d6d389129dfac2a610381992ef
Merge: 2497fd29 76ced7cb
Author: emonPi <[[email protected]](mailto:[email protected])>
It does not get less odd!
Can you please try this…
sudo git diff stable
then
and in both cases post the output please.
