Hello,
Everything works fine until error appeard for my 3 Emon bases with only one EmonTH each…
It normally pushs to my custom server a few times and now it is stuck in loop…
2020-06-29 12:01:26,062 INFO surya-monitoring-server sending: http://surya-monitoring.com/input/bulk.json?apikey=E-M-O-N-C-M-S-A-P-I-K-E-Y&data=[[1593428485.8013804,10,22.200000000000003,0,36.9,3.2,-69]]&sentat=1593428486
2020-06-29 12:01:36,080 WARNING surya-monitoring-server surya-monitoring-server couldn't send to server: HTTPConnectionPool(host='surya-monitoring.com', port=80): Max retries exceeded with url: /input/bulk.json?apikey=BLABLABLABLA (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7488bd70>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution'))
2020-06-29 12:01:36,082 WARNING surya-monitoring-server Exception caught in surya-monitoring-server thread. Traceback (most recent call last):
File "/opt/openenergymonitor/emonhub/src/emonhub_interfacer.py", line 32, in wrapper
return f(*args)
File "/opt/openenergymonitor/emonhub/src/emonhub_interfacer.py", line 127, in run
self.action()
File "/opt/openenergymonitor/emonhub/src/emonhub_interfacer.py", line 198, in action
self.flush()
File "/opt/openenergymonitor/emonhub/src/emonhub_interfacer.py", line 216, in flush
if self._process_post(databuffer):
File "/opt/openenergymonitor/emonhub/src/interfacers/EmonHubEmoncmsHTTPInterfacer.py", line 71, in _process_post
reply = self._send_post(post_url, {'data': data_string, 'sentat': str(sentat)})
File "/opt/openenergymonitor/emonhub/src/emonhub_interfacer.py", line 257, in _send_post
return reply.text
Fir st I though It was a limitation of my custom server which cannot handle some many posted data, but there are really not to many : for each of my base the value sendinterval = 120…
Do you have this kind of experience with emonHub?
