Hi all,
I’m facing some issue when trying to accomplish the following with the emonhub.
I have an EmonTx hardware, in the serial output I have connected an espeasy module configured as a serial2net tcp. That works and with Socat I’m receiving the data flow in the linux server where the emoncms is installed.
As you can see my socat is running as daemon and creating this port: /tmp/ttyV0
/usr/bin/socat -d pty,link=/tmp/ttyV0,waitslave tcp:192.168.blah.blah:1234
I can connect locally to this /tmp/ttyV0 and I can see the output from emontx published periodically. So basically it works.
The problem comes from the emonhub, no matter what I do, I always get this message
2022-09-18 10:23:20,522 INFO MainThread Opening hub…
2022-09-18 10:23:20,522 INFO MainThread Logging level set to DEBUG
2022-09-18 10:23:20,522 INFO MainThread Creating EmonHubSerialInterfacer ‘Serial’
2022-09-18 10:23:20,522 ERROR MainThread Unable to create ‘Serial’ interfacer: module ‘serial’ has no attribute ‘SerialException’
This is the setup part related to the serial conf in my emonhub.conf
[[Serial]]
Type = EmonHubSerialInterfacer
[[[init_settings]]]
com_port = /tmp/ttyV0
com_baud = 9600 # 9600 for old RFM12Pi
[[[runtimesettings]]]
pubchannels = ToEmonCMS,
subchannels = ToSerial,
Any idea why is failing to create the serial interfacer?
