Today, I temptatively upgraded my raspery pi and EmonCMS (within the application using the dedicated upgrade buttons). A subsequent check of the database check resulted in an error (I forgot the details). After a few login out an reboot of the raspberry, I am in a situation where I cannot log anymore: getting the error mesage Can’t connect to MySQL server on ‘127.0.0.1’. The issue seems to be related to the MySQL service that does not start. I tried to start manually bit it immediately fails. Ath this point I would like to know if
what are the possible reason for MySQL service not starting
possible solutions to solve the proble
a way to backup the MySQL database (and later recover the data) without having the service running.
● mysql.service - LSB: Start and stop the mysql database server daemon
Loaded: loaded (/etc/init.d/mysql)
Active: failed (Result: exit-code) since Mon 2019-01-14 16:29:22 CET; 1h 40min ago
Process: 1722 ExecStart=/etc/init.d/mysql start (code=exited, status=1/FAILURE)
Jan 14 16:29:22 emonpi mysql[1722]: /etc/init.d/mysql: ERROR: The partition...d!
Jan 14 16:29:22 emonpi systemd[1]: mysql.service: control process exited, c...=1
Jan 14 16:29:22 emonpi systemd[1]: Failed to start LSB: Start and stop the ...n.
Jan 14 16:29:22 emonpi systemd[1]: Unit mysql.service entered failed state.
Hint: Some lines were ellipsized, use -l to show in full.
Have you tried the button again? If not, can you please post the contents of /home/pi/data/emonpiupdate.log
If you have used the button more than once then the file will be less useful as it is cleared (I think) each time.
Could you do this please (use -l switch).
When you post the output, please put 3 backticks (top left of keyboard) on a line before the pasted output and then 3 more on a line below the pasted output (if you edit your post above, you will see what I have done).
I finally found the origin of my problem. I run out of SD card space! I am using a hard drive but I did not properly set the use of the latter. I have now to see if I can restart the MySQL service when the partition is increases and get access to the my data.
