Hi we have puchased several Emonpi to log data in several buildings, is it possible to export the data to one Emoncms account allowing remote veiwing? If I have to set up seperate accounts then is it possible to transfer some of the nearly £600 of credit to other accounts?
It should certainly be possible. You need to ensure that each sends the data with an unique identity, otherwise the data from several emonPi’s will end up in the same Feed. Obviously, each sends its data with the same APIkey - the one belonging to your emoncms.org account.
(You could equally send all the data to one emonPi - by sending to its IP address with its APIkey.)
