Turn off LCD backlight
I am on versions 7.1.3.T2 | Wifi v5.0.2 and I was wondering if the RAPI calls no longer work?
I was using http://192.168.0.100/r?json=1&rapi=$FB+0 which was able to switch off the LCD light but it no longer works, comes back with {"cmd":"$FB 0","error":"RAPI_RESPONSE_BLOCKED"} and even on the ESVE UI says undefined.
Perhaps the http api can also be used to apply the same? Is there a command for that now?
RAPI (write) was disabled in the v5 release, but this feature was missed in the HTTP API. We will be adding in a future release, probably as a ‘screen saver’ function.
