This system was very close to being a standard emonSD-30Oct18, with the exception of trying to install phpmyAdmin. This failed installation caused problems when I tried to do the upgrade the first time from the Admin menu. I removed the phpmyAdmin, then the update from the Admin menu worked.
This system is just a RPi 3B+ with no additional hardware.
Now I had been having problems with sync, but I can’t determine if I have the updated module as it doesn’t show the version number in the admin section.
Emoncms Version low-write 9.9.8-beta
Modules Administration | App v1.2.1 | Backup v1.1.6 | EmonHub Config v1.1.0 | Dashboard v1.3.3 | Device v1.2.1 | EventProcesses | Feed | Graph v1.2.3 | Input | Postprocess v1.0.0 | CoreProcess | Schedule | Network Setup v1.0.0 | sync | Time | User | Visualisation | WiFi v1.3.1
borpin
(Brian Orpin)
1 March 2019 06:56
2
Hi, on the Administration page, click on
and paste the output into a message here. No further formatting required.
I suspect in helping solve the issue, you moved onto the master branch rather than stable.
Cheers
Sorry I mixed up the version text file on the update to 9.9.8. I’ve removed the beta tag now, if you run update again it should show 9.9.8. This was a minor update to fix a missing icon on the feeds page.
Ok, great. I was having one of “those” days yesterday and I thought I had caused the problem.
Thank you both for your help.
I notice also that some of the module version numbers are not showing in the Admin/Server Information. Particularly Sync.
Server Information
Services
emonhub
Active Running
emoncms_mqtt
Active Running
feedwriter
Active Running - sleep 60s
service-runner
Active Running
emonPiLCD
Active Exited
redis-server
Active Running
mosquitto
Active Running
Emoncms
Version
low-write 9.9.8
Modules
Administration : App v1.2.1 : Backup v1.1.6 : EmonHub Config v1.1.0 : Dashboard v1.3.3 : Device v1.2.1 : EventProcesses : Feed : Graph v1.2.3 : Input : Postprocess v1.0.0 : CoreProcess : Schedule : Network Setup v1.0.0 : sync : Time : User : Visualisation : WiFi v1.3.1
Git
URL: GitHub - emoncms/emoncms: Web-app for processing, logging and visualising energy, temperature and other environmental data : Branch: * stable : Describe: v9.5.1-1775-gd0db7a57
Server
OS
Linux 4.14.71-v7+
Host
emonpi : emonpi : (192.168.1.122)
Date
2019-03-02 04:12:03 UTC
Uptime
04:12:03 up 1 day, 7:37, 0 users, load average: 0.02, 0.07, 0.08
HTTP
Server
Apache/2.4.25 (Raspbian) HTTP/1.1 CGI/1.1 80
MySQL
Version
5.5.5-10.1.23-MariaDB-9+deb9u1
Host
127.0.0.1 (127.0.0.1)
Date
2019-03-02 04:12:02 (UTC 00:00)
Stats
Uptime: 113854 Threads: 3 Questions: 127929 Slow queries: 0 Opens: 30 Flush tables: 1 Open tables: 24 Queries per second avg: 1.123
Redis
Version
3.2.6
Host
localhost:6379 (127.0.0.1)
Size
Uptime
1 days
MQTT Server
Version
Mosquitto 1.4.10
Host
localhost:1883 (127.0.0.1)
Pi
Model
Raspberry Pi 3 Model B+ Rev 1.3 - 1 GB (Sony UK)
SoC
Broadcom BCM2835
Serial num.
A2DA3FB3
Temperature
CPU: 57.46°C - GPU: 57.5’C
Release
emonSD-30Oct18
Memory
RAM
Used: 17.24% Total: 976.74 MB Used: 168.34 MB Free: 808.39 MB
Swap
Used: 0.00% Total: 100 MB Used: 0 B Free: 100 MB
Disk
Mount
Stats
Used: 40.34% Total: 3.81 GB Used: 1.54 GB Free: 2.1 GB
/boot
Used: 51.69% Total: 42.52 MB Used: 21.98 MB Free: 20.54 MB
/home/pi/data
Used: 4.49% Total: 10.73 GB Used: 493.48 MB Free: 9.71 GB
PHP
Version
7.0.33-0+deb9u1 (Zend Version 3.0.0)
Modules
apache2handler : calendar v7.0.33-0+deb9u1 : Core v7.0.33-0+deb9u1 : ctype v7.0.33-0+deb9u1 : curl v7.0.33-0+deb9u1 : date v7.0.33-0+deb9u1 : dom v20031129 : exif v7.0.33-0+deb9u1 : fileinfo v1.0.5 : filter v7.0.33-0+deb9u1 : ftp v7.0.33-0+deb9u1 : gd v7.0.33-0+deb9u1 : gettext v7.0.33-0+deb9u1 : hash v1.0 : iconv v7.0.33-0+deb9u1 : igbinary v2.0.1 : json v1.4.0 : libxml v7.0.33-0+deb9u1 : mbstring v7.0.33-0+deb9u1 : mcrypt v7.0.33-0+deb9u1 : mosquitto v0.4.0 : mysqli v7.0.33-0+deb9u1 : mysqlnd vmysqlnd 5.0.12-dev - 20150407 - $Id: b5c5906d452ec590732a93b051f3827e02749b83 $ : openssl v7.0.33-0+deb9u1 : pcre v7.0.33-0+deb9u1 : PDO v7.0.33-0+deb9u1 : pdo_mysql v7.0.33-0+deb9u1 : Phar v2.0.2 : posix v7.0.33-0+deb9u1 : readline v7.0.33-0+deb9u1 : redis v4.1.1 : Reflection v7.0.33-0+deb9u1 : session v7.0.33-0+deb9u1 : shmop v7.0.33-0+deb9u1 : SimpleXML v7.0.33-0+deb9u1 : sockets v7.0.33-0+deb9u1 : SPL v7.0.33-0+deb9u1 : standard v7.0.33-0+deb9u1 : sysvmsg v7.0.33-0+deb9u1 : sysvsem v7.0.33-0+deb9u1 : sysvshm v7.0.33-0+deb9u1 : tokenizer v7.0.33-0+deb9u1 : wddx v7.0.33-0+deb9u1 : xml v7.0.33-0+deb9u1 : xmlreader v7.0.33-0+deb9u1 : xmlwriter v7.0.33-0+deb9u1 : xsl v7.0.33-0+deb9u1 : Zend OPcache v7.0.33-0+deb9u1 : zlib v7.0.33-0+deb9u1
Client Information
HTTP
Browser
Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/72.0.3626.119 Safari/537.36
Screen
Resolution
1680 x 1050
Window
Size
1663 x 947
borpin
(Brian Orpin)
2 March 2019 10:46
6
Putting in version numbers is something that has been developed over time and not all Modules have them, mostly those Modules that are ‘core’ i.e. that are installed from the main repo.
