I’ve got a few other things on the go at the moment so I can’t make any promises…
When I get a chance I’ll take a look.
The majority of the code for the apps in the .php files is actually JavaScript (the apps are primarily client side)
Greebo, on the Time of Use app, how do I configure a time that starts at the half-hour? My rate is as follows:
12:00am - 5:59am – Off Peak
6:00am - 9:59am – Shoulder
10:00am - 12:29 pm – Peak
12:30 pm - 5:29 pm – Shoulder
5:30 pm - 7:59 pm – Peak
8:00 pm - 11:59 pm – off-peak.
I tried 0:0,6:1,10:2,1230:1,1730:2,20:0 but it is logging power consumed at 5:00 pm as being Peak instead of Shoulder.
The closest I’ve come is: 0:0,6:1,10:2,13:1,17:2,20:1
Thanks!
The short answer is, you can’t.
When I wrote it, all of the time of use periods I was aware of started and ended on the hour.
Hi @Greebo thanks for your work on the Time of Use app. I’m also in Australia. I have been able to get the ‘My Electric’ app working with both Power Now and cumulative use Today inputs. But for some reason I can only get the standard ‘Time of use’ app working with Power Now and the ‘Time of use CL’ version doesn’t work at all. They all have the same feeds and settings. I’ve added the settings to the last screenshot.
Any ideas?
Do you have <1 day of data in EmonCMS? If so, wait until tomorrow and they’ll both work a lot better.
I’ve started working on a different version that combines those two different apps into a single app with various options so you can choose to include a controlled load or not, include solar or not, etc. but my paying job has gotten in the way. After working on those two apps, I have a better understanding of how I could do things better the third time and will be including those in an update, but I can’t promise that any time soon!
Yes! Today daily cost is working. Thank you.
Screen Shot 2021-08-12 at 11.51.18 am
I am looking for a way to get this cost data into Home Assistant. I know EmonCMS has an api but I can only see feeds in the /feed/list.json. Is there a way to output the calculations from your app? I have tried scraping but both daily cost and energy use the same css selector #kwh_today
The short answer is no.
Under the covers, the app is simply using the EmonCMS feeds api to get the data being presented, so it is feasible for you to use the same calculations (and feed APIs) for your own purposes, but you’d have to do a bit of reverse engineering of the App code to do that.
Its just a massive javascript file, so you can view it in the browser developer pane (in the sources panel) and see what gets called where. That’s actually how I went about debugging it when developing it, you can even step through the code in the debugger if you had the inclination.
Ok thanks for the explanation. Unfortunately I am not a programmer so the best I can do is simple scripts to scrape information. Is there a way to scrape outputs from javascript apps? If not would you consider adding this to your next version?
What information are you specifically after to feed into HA?
My main goal is to get the daily cost into HA. Monthly would be great too. I haven’t found any other calculators out there that can do three tariffs (weekends + weekdays) and a supply charge.
EDIT: The averages would be really cool to get into HA too.
I chucked this python script together last night and this morning - its a bit of a hack job, but it will probably do what you need.
I started including solar but it is not currently included, neither is the daily supply charge, but that’s fairly easy to add.
It calculates the hourly usage based on the feed ID in feed_id_import which should be a cumulative kWh feed of imported energy and then calculates the cost of that hour’s worth of energy based on the tarrif for the hour in question.
It then spits out a total of kWh and $ for each day
On my system, it produces output like this:
pi@emon-pi:~ $ ./dailycost.py
Daily totals: 0 : 0 kWh @ $ 0
Daily totals: 01 : 23.51611328125 kWh @ $ 7.580610351562498
Daily totals: 02 : 20.59033203125 kWh @ $ 6.2274365234375
Daily totals: 03 : 21.908203125 kWh @ $ 6.8537011718750005
Daily totals: 04 : 32.033203125 kWh @ $ 9.767094726562497
Daily totals: 05 : 23.73046875 kWh @ $ 7.2191748046874995
Daily totals: 06 : 26.61669921875 kWh @ $ 7.6351123046875005
Daily totals: 07 : 28.73193359375 kWh @ $ 9.758833007812498
Daily totals: 08 : 32.28173828125 kWh @ $ 12.026528320312499
Daily totals: 09 : 26.72314453125 kWh @ $ 7.4077783203125
Daily totals: 10 : 26.6982421875 kWh @ $ 9.02138671875
Daily totals: 11 : 21.82470703125 kWh @ $ 6.123593749999999
Daily totals: 12 : 24.81201171875 kWh @ $ 7.022583007812499
Daily totals: 13 : 9.101576653650227 kWh @ $ 1.6563322295585658
The total for today (shown in the last line) is “until now”
I’ve used “rough guess” values for the tarrifs, I didn’t actually look them up, so you’ll need to make sure you change them where it says in the script.
I don’t use HA, so I’m not sure what format you need data in to push it into HA, but it should be fairly simple for you to modify this with the required format.
On to the Python3 script!
#!/usr/bin/env python3
import datetime
import sys
import json
import requests
import time
emonCmsJson  = { }
emon_readKey = 'XXXXXXXXXXXXXXXXXXXXXXXXX' # Enter readAPIkey here - CHANGE THIS
emon_url        = 'http://emon-pi.local/feed/data.json' # If your EmonCMS has a different name or IP, update it here
feed_id_import = 91 # kWh feed Id of imported energy - CHANGE THIS
feed_id_export = 92 # kWh feed Id of exported energy - CHANGE THIS
# These should be the various tarrifs charged by your retailer
tarrif_rates = [0.18, 0.29, 0.59]  # CHANGE THESE
# If you have solar, update this with your feed-in rate
tarrif_feedin = 0.17 # CHANGE THIS
# These values are my standard tarrif periods, CHECK THESE
# update these with the index into the rates above, startng at 0
# First is the weekday times
tarrif_times_wd = [
    0, # 00:00 - 00:59
    0, # 01:00 - 01:59
    0, # 02:00 - 02:59
    0, # 03:00 - 03:59
    0, # 04:00 - 04:59
    0, # 05:00 - 05:59
    0, # 06:00 - 06:59
    1, # 07:00 - 07:59
    1, # 08:00 - 08:59
    1, # 09:00 - 09:59
    1, # 10:00 - 10:59
    1, # 11:00 - 11:59
    1, # 12:00 - 12:59
    1, # 13:00 - 13:59
    2, # 14:00 - 14:59
    2, # 15:00 - 15:59
    2, # 16:00 - 16:59
    2, # 17:00 - 17:59
    2, # 18:00 - 18:59
    2, # 19:00 - 19:59
    1, # 20:00 - 20:59
    1, # 21:00 - 21:59
    0, # 22:00 - 22:59
    0  # 23:00 - 23:59
# now for the weekend/pub holiday times
tarrif_times_we = [
    0, # 00:00 - 00:59
    0, # 01:00 - 01:59
    0, # 02:00 - 02:59
    0, # 03:00 - 03:59
    0, # 04:00 - 04:59
    0, # 05:00 - 05:59
    0, # 06:00 - 06:59
    1, # 07:00 - 07:59
    1, # 08:00 - 08:59
    1, # 09:00 - 09:59
    1, # 10:00 - 10:59
    1, # 11:00 - 11:59
    1, # 12:00 - 12:59
    1, # 13:00 - 13:59
    1, # 14:00 - 14:59
    1, # 15:00 - 15:59
    1, # 16:00 - 16:59
    1, # 17:00 - 17:59
    1, # 18:00 - 18:59
    1, # 19:00 - 19:59
    1, # 20:00 - 20:59
    1, # 21:00 - 21:59
    0, # 22:00 - 22:59
    0  # 23:00 - 23:59
# lets do this month's costs per day
# Start at 23:59 on the previous day, that gives us a starting value and then values up to hh:59:59
# for each hour period - this makes the claculations easier
month_start = datetime.datetime.today().replace(day=1,hour=0,minute=59,second=59,microsecond=0)
month_start = (month_start + datetime.timedelta(hours=-1)).timestamp() * 1000
now = datetime.datetime.now().timestamp() * 1000
payload_import = { 'apikey': emon_readKey, 'id': feed_id_import, 'start': month_start, 'end': now, 'interval': 3600 }
try:
    r = requests.get(emon_url, params=payload_import)
    if r.status_code != 200:
        print('HTTP response code is [' + str(r.status_code) + ']')
    else:
        last_kwh = 0
        last_day = 0
        day_total_kwh = 0
        day_total_cost = 0
        # need to iterate through the values returned, the timestamp is for the START of the period
        # so we need to drop everything back by 1 hr.
        for val in r.json():
            if last_kwh == 0:
                # Just starting
                last_kwh = val[1]
            else:
                val_date = datetime.datetime.fromtimestamp(val[0]/1000)
                day = val_date.strftime("%d")
                if day != last_day:
                    print('Daily totals:', last_day, ':', day_total_kwh, 'kWh @ $', day_total_cost)
                    day_total_kwh = 0
                    day_total_cost = 0
                    last_day = day
                dow = val_date.strftime("%w") # day of Week, Sunday is 0
                hr = int(val_date.strftime("%H"))
                interval_kwh = val[1] - last_kwh
                last_kwh = val[1]
                day_total_kwh += interval_kwh
                if dow == 0 or dow == 6:
                    # Use the weekend rates
                    kwh_rate = tarrif_rates[tarrif_times_we[hr]]
                else:
                    # use the weekday rates
                    kwh_rate = tarrif_rates[tarrif_times_wd[hr]]
                hr_cost = kwh_rate * interval_kwh
                day_total_cost += hr_cost
                #print(day, '-', hr, ': ', interval_kwh, ' $', hr_cost, '[$', kwh_rate, '/kWh]')
except ValueError as err:
    print('Caught http exception: ' + str(err))
    r.close()
Oh, you might also need to install the requests Python module:
https://docs.python-requests.org/en/master/user/install/
