could you see if there is a line number associated with the javascript error in the console log?
pb66
(Paul)
23
Iām actually got beta off at the moment, but I thought I would try editing a device that was previously giving the error (in the new look inputs page) form the device page and it does the same error from there. So this is a device module thing not a device integration or new look thing.
And, now Iāve posted that I have just recalled noticing that there is a commit on the master branch of the device module that hasnāt made it to the indexedinputs branch that maybe related. (see Comparing indexedinputs...master Ā· emoncms/device Ā· GitHub)
And⦠when I try to update the database I get caught in the loop previous reported by @Paul
and so onā¦
I will look into deleting the empty devices or adding an input so they are not empty to see if it has any impact, I will try to confirm next time I switch beta on.
Even with the cookie working, it will still annoy the hell out of me if I use another machine or the cookie expires, why canāt the existing default collapsed or default uncollapsed setting be reused in the beta version? That setting is the single best feature of the existing inputs page. I would prefer it is always fully closed when I open the page or refresh, I would prefer it not to remember what I had open previously, itās like returning to a cluttered desk, I liked starting afresh each visit.
Thanks for spotting, Iāve merged that change now into device:indexedinputs. I also updated emoncms:indexedinputs yesterday to contain the latest from the master branch.
Im personally quite fond of the saved collapsed/uncollapsed state feature. I found always arriving at a collapsed view when I wanted to generally see the status of the emonpi or emontx node a pain
pb66
(Paul)
25
Iām not so concerned about the saved state, I can live with that (if it works correctly) and I understand it is required for the sideswipe mobile views etc. What I cannot live with is the default (if thereās no cookie or itās expired etc) being to expand all. There must be a hard-coded default to fully uncollapsed in the new views as that is the action weāre seeing. I donāt understand why that cannot use the existing setting for open or closed.
I understand adding saved state, but I do not understand it being at the cost of an existing feature when it neednāt be. The open/closed default user setting should also dictate the first action of the collapse/uncollapse button on page. If I do come to an old previous āsaved stateā then clicking the collapse/uncollapse button should always collapse all (if user setting is āclosedā) otherwise not only are we met with a partially collapsed/uncolapsed page but it will take 2 clicks of the button to get to the users preferred default state.
If itās not possible to use the existing setting, then please at least point out where in the code it is hard-coded (both the page and button states) so that I/we can make local changes and stash them across updates, this as you can understand is going to seriously impair the experience of using emoncms.
Weāve sat on opposite sides of this fence before which led to you kindly adding the default user setting in recognition of the fact users differ, I do not understand why that feature has to be lost to add āsaved stateā.
