the pin connections to the UART board TXD and RXD ??
no worries I was just asking if they were referring to the rs485 that has the simple connection such as the above which is 4 wire that you can connect to common TTL connectors or the one below which is 5 -6 connection two extra to enable and disable send and receive .
