Running EVSE with 4.1.4 firmware,… and reporting back to emonPicms…
Looking at ‘inputs’ on cms,… the temperature is 10x actual displayed ( 70 degrees C,. rather than 7.0C) temperature from EVSE web page,… is this me?,… or a known issue to this firmware.
Or am I just looking at the data wrong,…
Yours confused…
That’s how the raw data is transmitted, if you use the device config to apply input processing to convert the Input to Feeds this will be converted to a float. Or you can do this yourself by applying a x0.1
Emoncms input process, see OpenEVSE / EmonEVSE Setup Guide — OpenEnergyMonitor 0.0.1 documentation
Tx Glyn,… I had done that,… but thought I was just kludging something that didn’t need a fudge,… and I was doing something else incorrectly
Adding to Glyn’s answer - it’s something we generally do when we need to send a smallish decimal number (less than 327.67 or 3276.7) with one or two digits of decimal precision - multiply by 10 or 100 at source, send it as an integer (2 bytes - it’s smaller than a double), then divide it back down to size at the receiving end.
