I recently purchased an emonPi and 4 emonTH pre-configured.
After configuring the inputs and feeds, I noticed the reading for t1,t2,t3,t4 are always 0’C
Power1 ,Power2 and Pulse are displaying the correct values
Is there something else that need to be configured ?
LCD shows the following
_
Jul 15 07:17
Uptime 1.01 days
_
emonSD-24Jul20
Serial : xxxx
_
WiFi : YES 52%
192.168.x.xx
_
Power1:33W
Power2:34W
_
VRMS: 0V
Pulse 1p
_
Temp 1: 0’C
Temp 2: 0’C
_
Hello @santheep yes the emonth values should keep updating every 60 seconds. It looks like you have an entry for the emonth in the emonhub log as well, do they keep coming in or is it just the once?
Those are the same readings as the image above, from the same temperature sensors – the ones that can be connected directly to the RJ45 socket on your emonPi - and they are not what you are looking for.
It is the last part of that screenshot that shows one of your emonTHs:
I have verified that all 4 emonTH are powered up , the green LED appeared for a few seconds
but as you can see from the screenshots, I am not able to see any new emonTH nodes besides the emonth5 and emonth8, which are our current working emonth nodes.
I have also made sure that the 4 emonTH nodes have different DIP switch set as recommended
First emonTH: off off
Second emonTH: on off
Third emonTH: off on
Fourth emonTH: on on
Hello @santheep Could you try powering up one EmonTH at a time to see if any emonth related inputs update? Could you also check that the green LED light on each EmonTH lights up breifly when you insert the batteries?
Managed to resolve the issue.
I disabled the older temperature nodes, and only enabled the 4 new temperature nodes and then I was able to see all 4 new temperature nodes.
That sounds as if you had duplicate NodeIDs between the “old” and the “new”. Every device on your radio network must have its own unique NodeID. As you have 7 (the emonTHs plus the emonPi), you will need to edit the emonTH sketch to change two of them, and re-load.
I second that. Platformio screwed up my OEM system when I installed it - it took hours to straighten everything out again, after I’d sent it to the bit bucket.
