System not showing up in HeatpumpMonitor.org
I recently added my system to the platform but it is not showing up in the list even though it says shared and published?
Hello! Welcome to the forum :wave:
Which system is it?
You may need to shorten the “Stats time period” at the top of your system has less than a year of data.
Some systems may also be hidden based on these checkboxes:
Thank you,
Its a Heatpump integration and based in Leighton Buzzard.
I’ve changed the stats to all and selected Heatpump integration and its still not there for me
I guess it’s this system then: https://heatpumpmonitor.org/system/view?id=549
There looks to be a problem with the data that HPM is struggling to read. Might need @TrystanLea to look into it…
Yes thats the one, that would be great if @TrystanLea can
Fixed, the spaces in the URL were causing the issue. Was that the URL from selecting the system from the dropdown menu?
Great thank you, @TrystanLea
Yes that was from selecting the system from the dropdown
