Sync from emonPi to local emonCMS
I am trying to use Sync to get Feeds from an emonPi to my local emoncms, but seem to have trouble with some data.
My emonPi inputs are configure like:
and these appear in the emonPi Feeds thus:
Now on my EmonPi I go to Sync Feeds and enter the login details for my local emonCMS I see:
If I click ‘Upload’ for any of ‘vrms’, ‘use_kwh’, ‘use’, or ‘t1’ then the Uploads all work as expected , but if I try upload for any of the others i get:
(the behind ones catch up after a while).
then on my emonCMS:
and in the Data Viewer (Graphs) all of the ‘kwhd’, Min or Max values appear empty.
Am I doing something wrong ?
Hello @G0LGS it looks like there is an issue with uploading the PHPTIMESERIES feeds. Checking here I can see that Im getting the same result as you are.
I’ve created an issue here to track this bug PHPTimeSeries feeds not uploading · Issue #34 · emoncms/sync · GitHub I will try and take a look at it later today or tomorrow.
At least it is good to know it wasn’t just me doing something wrong.
Hello. Any workaround for this problem?
I’m using [low-write 10.2.1] and trying to sync the feeds with a remote emoncms 11.0.7. All seems to work well but PHPTIMESERIES feeds.
