Suggestions to new hardware!
Hello all, ever considered creating a small, affordable, device with only one sensor for example? Like a mini emontx! Intended to be used locally on small devices, for example to use on a heater!
I seen how to create my own devices but a official product would be most welcome!
Thank you all for your work and time!
Best regards
If you mean a device to measure power being used then I’d point to towards the Sonoff range - both plug in and hardwired varieties available. Flash with Tasmota and then no leakage of data either.
Hello @borpin, yes I allready do that, but to low consumption devices! I use a sonoff pow 16amp max for example! But if the device is over 10 amp I don’t feel secure using a sonoff, several reports on the internet of them catching fire!
Thank you
