In the “Connect” section of the Guide under " Assign static IP (Optional & Advanced)"
It refers to using the rpi-rw. This command should no longer be required, at least I didn’t need it.
Under the " 6. Shutdown" section, which should actually be “7”, I think it is also worth including the SSH command “sudo shutdown” as an alternative or for those not running the emonPi.
