Hello,
The intention is that I will show 8 devices of 230V which device is on and which is not.
For this purpose I first made a test setup (see appendix).
Miraculously I got the whole thing working.
To go a step further I bought 8x clamps, 3x EmonTX and 3xEmonBase.
I think I connected these as I should and I want them (see appendix).
- 2 clamps an EmonTX-01 and the TX-01 to the EmonBase-01
- 4 clamps an EmonTX-02 and the TX-01 to the EmonBase-02
- 2 clamps an EmonTX-03 and the TX-01 to the EmonBase-03
(In theory, any EmonTX can go to 1 EmonBase, but I didn’t choose to do so because the range of the signal is not sufficient if the EmonTX is spread further apart)
Now I have troubles with the following:
Since the EmonTX transmitters are now too close to the 3 EmonBase receivers, I receive all the data for each EmonCMS. Can I adjust this in the EmonHub in such a way that I only receive the data from a certain EmonTX?
In addition, they have different values. 2 give power 1, power2, power 3 etc and the others P1, P2, P3 etc. I would like to see these uniformly. Can I disable values that I don’t want to show in my EmonCMS in the EmonHub?
Which routerports do I need to open and what action do I need to take to get everything up and running?
Also, I can’t quite get out of the write-/read keys on different levels…
I know, it’s a lot of questions, I hope you can help me out.
When the project is finished, I will of course post the results, including photos.
Who would like to help me make this commonplace?
Greetings, Peter
