Hi, my emonTX stops running after an hour, I followed the troubleshooting guide and have linked the output below.
Any ideas?
pi@emonpi(ro):~$ sudo service emonhub status
● emonhub.service - LSB: Start/stop emonHub
Loaded: loaded (/etc/init.d/emonhub)
Active: active (exited) since Fri 2017-12-01 09:17:19 UTC; 1h 25min ago
Process: 505 ExecStart=/etc/init.d/emonhub start (code=exited, status=0/SUCCESS)
Dec 01 09:17:19 emonpi sudo[545]: root : TTY=unknown ; PWD=/ ; USER=root ; ...ub
Dec 01 09:17:19 emonpi sudo[545]: pam_unix(sudo:session): session opened fo...0)
Dec 01 09:17:19 emonpi sudo[545]: pam_unix(sudo:session): session closed fo...ot
Dec 01 09:17:19 emonpi sudo[637]: root : TTY=unknown ; PWD=/ ; USER=root ; ...og
Dec 01 09:17:19 emonpi sudo[637]: pam_unix(sudo:session): session opened fo...0)
Dec 01 09:17:19 emonpi sudo[637]: pam_unix(sudo:session): session closed fo...ot
Dec 01 09:17:19 emonpi sudo[648]: root : TTY=unknown ; PWD=/ ; USER=root ; ...ub
Dec 01 09:17:19 emonpi sudo[648]: pam_unix(sudo:session): session opened fo...0)
Dec 01 09:17:19 emonpi sudo[648]: pam_unix(sudo:session): session closed fo...ot
Dec 01 09:17:19 emonpi sudo[675]: root : TTY=unknown ; PWD=/ ; USER=root ; ...ub
Dec 01 09:17:19 emonpi sudo[675]: pam_unix(sudo:session): session opened fo...0)
Dec 01 09:17:19 emonpi sudo[675]: pam_unix(sudo:session): session closed fo...ot
Dec 01 09:17:19 emonpi emonhub[505]: Starting OpenEnergyMonitor emonHub: em...k.
Dec 01 09:17:19 emonpi systemd[1]: Started LSB: Start/stop emonHub.
Hint: Some lines were ellipsized, use -l to show in full.
pi@emonpi(ro):~$ sudo service emonhub status -l
pi@emonpi(ro):~$ tail /var/log/emonhub/emonhub.log
2017-12-01 10:31:16,062 DEBUG MQTT Publishing: emon/gasNode-0-10/tempBoiler 300
2017-12-01 10:31:16,063 DEBUG MQTT Publishing: emon/gasNode-0-10/tempHotWater 300
2017-12-01 10:31:16,064 DEBUG MQTT Publishing: emon/gasNode-0-10/temp3 300
2017-12-01 10:31:16,066 DEBUG MQTT Publishing: emon/gasNode-0-10/temp4 300
2017-12-01 10:31:16,067 DEBUG MQTT Publishing: emon/gasNode-0-10/temp5 300
2017-12-01 10:31:16,068 DEBUG MQTT Publishing: emon/gasNode-0-10/temp6 300
2017-12-01 10:31:16,070 DEBUG MQTT Publishing: emon/gasNode-0-10/gasPulse 0
2017-12-01 10:31:16,071 INFO MQTT Publishing: emon/gasNode-0-10/rssi -39
2017-12-01 10:31:16,072 INFO MQTT Publishing: emonhub/rx/24/values 0,0,0,0,4.8,300,300,300,300,300,300,0
2017-12-01 10:31:16,073 INFO MQTT Publishing: emonhub/rx/24/rssi -39
pi@emonpi(ro):~$ sudo service mqtt_input status
● mqtt_input.service - Emoncms MQTT Input Script
Loaded: loaded (/etc/systemd/system/mqtt_input.service; enabled)
Active: active (running) since Fri 2017-12-01 10:08:19 UTC; 35min ago
Docs: https://github.com/emoncms/emoncms/blob/master/docs/RaspberryPi/MQTT.md
Main PID: 1996 (php)
CGroup: /system.slice/mqtt_input.service
└─1996 /usr/bin/php /var/www/emoncms/scripts/phpmqtt_input.php
Dec 01 10:08:19 emonpi systemd[1]: Started Emoncms MQTT Input Script.
pi@emonpi(ro):~$ tail /var/log/emoncms.log
2017-12-01 10:08:11.999|ERROR|phpmqtt_input.php|exception 'Mosquitto\Exception' in /var/www/emoncms/scripts/phpmqtt_input.php:112
Stack trace:
#0 /var/www/emoncms/scripts/phpmqtt_input.php(112): Mosquitto\Client->loop()
#1 {main}
2017-12-01 10:08:12.001|WARN|phpmqtt_input.php|Not connected, retrying connection
2017-12-01 10:08:21.271|ERROR|phpmqtt_input.php|exception 'Mosquitto\Exception' with message 'The client is not currently connected.' in /var/www/emoncms/scripts/phpmqtt_input.php:112
Stack trace:
#1 {main}
2017-12-01 10:08:21.291|WARN|phpmqtt_input.php|Not connected, retrying connection
pi
I just noticed after I finished my post
