Just loaded emonSD-07Nov16 and successful booted the raspberry pi up and tried to connect to pi@emonpi but the password emonpi2016 does not work.
$ ssh pi@emonpi
pi@emonpi's password: emonpi2016
Permission denied, please try again.
Did the password get changed for the emonSD-07Nov16 build?
should work
can you try with ssh pi@“ipaddress” instead ssh pi@emonpi …
just tried with mine and it works with the default password
pb66
(Paul)
26 January 2017 12:07
3
Are you sure CAPS lock is off and NUM lock on (if using numeric keypad) unless you have changed it, it should work as that is still the default password.
Yep tried the IP address also. CAPS and NUM were checked. I will reload the image and try again.
