Anyone else having trouble with the onboard WiFi module on the Pi3? - Specifically SSH access to their Pi (so far as I can tell, everything else, Onboard Apache web server etc etc all work just fine).
It’s a problem with the way SSH pre-marks QoS on any packets it creates, this problem is NOT related to the emonPi image - it’s all the Raspbian images (complaints about this are prolific on the Raspberry Pi forums).
Adding the following lines to the end of /etc/ssh/sshd_config fix the issue without any side effects;
#RaspberryPi 3 Onboard WiFi Fix
IPQoS cs0 cs0
