While Updating, the flash was corroded. Then, using “esptool.py erase_flash”, as suggested, the Flash was erased (in 10.4s) and a “Hard resetting via RTS pin” was made. However, there is no connection to the ESP_XXX.
I realize you posted this a while ago, but if the flash was erased then EmonESP needs to be reloaded completely - the easiest way being to use esptool.py to load the .bin files (including the spiffs .bin file).
