Source of small LiFePO4 cells?
Does anyone know a UK supplier of small ‘raw’ LiFePO4 cells?
I am thinking about making a 48v LiFePO4 pack to power a few low voltage electronic devices that are always-on in my house. I am on Octopus Agile, so it would be good to be able to power them reliably for long periods of higher energy prices.
But the smallest prismatic cells I can find seem to be 3.2v / 280 Ah, which is massive and too expensive for my needs. And the best cylindrical cells I could find are too expensive:
(that works out at about £800 per kWh!)
Hey Nicolas, I order mine from china slim pickings in the UK, and the USA
Gotion has a set of cylindrical cells that are reasonable and available
I’ll post some pricing and a contact person you can buy from shortly and see if that gets you what you’re after
https://docs.google.com/file/d/14WfSvV4Mm66WNJzz3VOTFWpiFrCbsZwa/edit?usp=docslist_api&filetype=msexcel
See if any of those are good, these are prices in china so still need to add shipping and tariffs if applicable
Yeah, finding small Coremax LiFePO4 cells in the UK is pretty hard these days. Most sellers have pretty much moved to the big prismatic stuff — 280Ah, 304Ah, 320Ah, 300Ah, etc. Anything smaller is either crazy overpriced or just not stocked.
I was looking for the same thing not long ago because I wanted a small 48V pack for some always-on devices (also on Octopus Agile, so I get the idea). But yeah… the smallest “real” prismatic cells I could find were 3.2V 300Ah, which is waaay more capacity and cost than I needed too.
Honestly, unless you really want to build it from scratch, it might be cheaper to just buy a prebuilt 48V battery. I came across an EGbatt 48V 300Ah LiFePO4 pack for about $1480, which surprised me because the price per kWh is stupidly low. By the time you buy cells + BMS + case + busbars + shipping, a DIY pack can easily cost more.
So yeah — small loose cells in the UK? Pretty much unicorns.
But grabbing a complete 48V pack might be the easiest (and weirdly cheaper) route if you just want something to run small loads during high Agile prices.
What I decided to do in the end was to get an Eco-worthy 24V 100Ah LiFePO4 Lithium battery pack - with built-in BMS in the January 2025 sales for £308.
I am running some things like my home server off it directly (which has a wide voltage input DC-DC converter). And then have a 12v DC-DC converter for other small devices. I am then also powering a PoE network switch off it, which I am using a 24v → 48v DC-DC converter to bring it up to the right voltage. I also have a USB-C adaptor, that works with 24v. So 24v has worked out quite well as an in-between voltage.
I have a couple of solar panels connected to a Victron MPPT, to charge the battery during the day. And then a Victron 24v charger, which tops the battery up using cheap electricity overnight, when there isn’t enough sun. And it is of course all tracked using EmonCMS :heart:
It was really cool to be able to play with some of this technology without spending thousands. And all working really well - need to write a blog post about it!
