Happy new year to you all
So I am once again relying on all your expertise please, I managed to get some readings from my sontex449 using the config Glyn posted but it seems to fail after running for different periods saying could not read from mbus. Could this be due to the fact that it is running on a D battery at 3.6v and not mains power. I have disconnected it completely at the moment but have the ds18b sensors and a smartrail x45m electric meter all recording and plotting on a graph. If anyone has any thoughts or ideas if I need to change my config I’d be grateful.
On another note my heat pumpis a grant aerona 6kw which has mbus enabled and can be read using home assistant, is there a config that can be used emonhub?
Afternoon all,
Does anyone know the voltage output from the 230v module on a sontex heat meter, I have one fitted with a d cell battery but i am struggling to pull data from the mbus sometimes it works and other times it can’t read it. should i move the power supply from my raspberry pi and power everything from the heat pump mointor board or could i use 2 power supplies 1 for the pi and 1 for the hat?
Happy new year @Satwelsh I think I recall that you have our heat pump HAT MBUS reader? Another user did report having difficulty reading from a Sontex531 using this HAT, he had more reliable results with another reader. Could we send you one of these for you to test and compare? I use the MBUS HAT with my Sontex531 which is mains powered and it’s been completely reliable but there must be some difference that’s we are missing.
Hi Trystan
That would be fantastic if you could, like i said it works sometimes then stops with no mbus connection.
Hi @Satwelsh, can you post your current config, please?
As soon as i am home i will post on here. Thanks Mike
Rather than screenshots, please copy and paste the text itself using the ‘preformatted’ button in the ribbon, Ctl-E or 3 ‘backticks’ (top left of the keyboard).
Have you configured 2 interfacers, one for M-BUS and another for the SDM?
Do you have 2 different devices to read?
Morning Brian
yes there are 3 altogther 1 for the sdm ( this is a smartrailx45m meter) but the same as
1 for the sontex449 and 1 for ds18 sensors, i do not have anything in the config for the hat board fitted on the pi, not sure if i need it. like i said it starts to pull data from the heat meter but then fails thia happens if i have nothing else connected and have deleted the config entries for the sdm and sensors?
hope this makes sense.
You need to post your whole config.
####################### emonhub.conf #########################
### https://github.com/openenergymonitor/emonhub/blob/emon-pi/configuration.md
####################### emonHub settings #######################
[hub]
loglevel = DEBUG
autoconf = 1
# use_syslog = yes
####################### Interfacers #######################
[interfacers]
[[EmonPi2]]
Type = EmonHubOEMInterfacer
[[[init_settings]]]
com_port = /dev/ttyAMA0
com_baud = 38400
[[[runtimesettings]]]
pubchannels = ToEmonCMS,
subchannels = ToRFM12,
[[DS18B20]]
Type = EmonHubDS18B20Interfacer
[[[init_settings]]]
read_interval = 10
nodename = sensors
[[SDM120]]
[[[init_settings]]]
device = /dev/serial/by-id/usb-1a86_USB2.0-Ser_-if00-port0
baud = 2400
read_interval = 10
nodename = sdm120
# prefix = sdm_
[[[[meters]]]]
[[[[[sdm120]]]]]
address = 1
registers = 0,12,18,24,30,70,72,76,
precision = 2,3,1,1,3,3,3,3,3
[[MBUS]]
Type = EmonHubMBUSInterfacer
[[[init_settings]]]
device = /dev/ttyAMA0
baud = 2400
read_interval = 10
validate_checksum = False
nodename = MBUS
[[[[meters]]]]
[[[[[heatmeter]]]]]
address = 7
type = standard
[[SPI]]
Type = EmonHubRFM69LPLInterfacer
[[[init_settings]]]
nodeid = 5
networkID = 210
[[MQTT]]
Type = EmonHubMqttInterfacer
[[[init_settings]]]
mqtt_host = 127.0.0.1
mqtt_port = 1883
mqtt_user = emonpi
mqtt_passwd = emonpimqtt2016
pubchannels = ToRFM12,
subchannels = ToEmonCMS,
# emonhub/rx/10/values format
node_format_enable = 0
nodevar_format_enable = 1
# Single JSON payload published - use with Emoncms MQTT
node_JSON_enable = 0
node_JSON_basetopic = emon/
[[emoncmsorg]]
[[[init_settings]]]
url = https://emoncms.org
senddata = 1 # Enable sending data to Emoncms.org
sendnames = 1 # Send full input names (compression will be automatically enabled)
interval = 30 # Bulk send interval to Emoncms.org in seconds
####################### Nodes #######################
## See config user guide: https://github.com/openenergymonitor/emonhub
## If autoconf is enabled above, node configuration will automatically
## populate based on templates listed in available.conf
[nodes]
Here’s my entire config
Thanks. Just a note, where is says Type text here you should replace that text with your config/log text so the new text is between the 3 backticks.
When you say stops, is that the whole emonhub log stops, or just the MBUS interfacer?
Does it stop completely, or just fail to read the data on occasions?
Yes just the MBus interfacer, If you look at the log between 19:44:12 and 19:44:20, that’s what it does continually after it fails for the 1st time. Do i need to add anything to my config for the hat board to be recognised and I should have a new power supply for my meter today incase the battery is not providing enough power to the Mbus to read correctly. My electric meter and temp sensors have worked flawlessly now for a week no matter how many times I shut down and restart the system. Any help would be great please Brian. and just a quick do you know if the grant aerona can be intergrated into the config to read directly from the unit to the HAT and pi please a bit like the Samsung?
Can you SSH into the Pi? I want o see if there are any error s from the Python script that is running (I’ll tell you how).
Can you post (as text) the log output when it works and the output when it fails? Just extract the lines relating to MBUS interfacer.
Hi Brian
yes no problem but i can’t do it till later as i am in work sorry if that’s ok. i’m comfartable ssh into the pi if you can tell me what script i have to type and where.
The new MBUS reader is in the post to you today, let me know how you get on with it.
Thank you I will try it tomorrow evening.
