Hozid guys, thank you for every one that has contributed towards Emoncms. I don’t know if it could be usefull to someone out there but I have taken some of the existing widgets and modified them so that they could better fit my needs. So if you can use them , happy I could also contribute!
- Is a Mod of the bar widget that uses a inverter image for the background , it will show the “watt” value of your inverter load.
inverter bar.zip (52.3 KB) - Is also a mod of the bar widget that will show you batteries state of charge in %. I would be nice it you could "move " the image to the fore ground and maybe someone could assist?
battery Bar.zip (10.5 KB) - Is a mod a of the LED widget. Basicly you can scale the widget to any rectangular size of you wanting. Worked wonders for what I wanted to do.
square led.zip (1.4 KB)
Regards
Paul
